Lg oled65b6v
  • blib
    • Feb 2012
    • 56
    Lg oled65b6v
    i was watching the TV when it turned itself off. On turning it back on the screen does not light up. The audio is OK. I have checked all the power supply output voltages 12v and 24v and these are OK.
    Could it be that the OLED panel has failed? Are there any checks i can do to work out if the panel has failed?
  • Diah
    • Feb 2013
    • 6435
    Re: Lg oled65b6v
    dont touch any things... since your LG now working and have sound no error only screen black search here i dfid wrote many time how to send command IN_STOP to make hard reset for LG.
    since the screen black you may after send the command In_Stop send with urs original RC thr code 0431 the TV will goes to STB. plug iit out from wall for 1-2 minute and then turn on... hope yours screen come back..
    if not and before do in_stop while you hear sound plug it out from the wall.. insert air mouse or usb mouse ant any usb port... and a usb key on its root one file mpeg ( video ) and plug it in tv.... start playing with mouse while you plug it back to wall .. this will help if the tv in deep sleep ( save mode ) to wake it up. good luck
    • blib
      • Feb 2012
      • 56
      Re: Lg oled65b6v
      Thanks for the reply. Imputing 0341 with TV remote but does not go to standby.
      • Diah
        • Feb 2013
        • 6435
        Re: Lg oled65b6v
        input the code after you send in_stop
        • blib
          • Feb 2012
          • 56
          Re: Lg oled65b6v
          Can you tell me how to input In_Stop? Thanks
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • SSBDADC234
            MacBook Pro 14". The screen DP chip failed.
            by SSBDADC234
            When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
            However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
            Testing the chip pins with a multimeter revealed a short circuit inside the chip.
            Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
            04-19-2024, 08:51 PM
          • michelhadid
            Crelander DS16 Dual screen BIOS Update failed recovery with CH341A
            by michelhadid
            Hey guys. Michel here. I´m trying to recover a Crelander DS16 Laptop (i7 10750h dual screen laptop, ZENBOOK DUO Clone).
            Laptop lost power and failed a BIOS Flash mid flash with AFUWIN/DOS. I of course made a backup beforehand, however, i can´t flash with AFUWIN/DOS now since it doesn´t boot/post anymore (black screen, fans on). I´ve read the BIOS chip (W25Q80DVSIG) with a CH341A Programmer, but AFUWIN Bios backup is 12MBytes and the CH341 read is a 1Mbyte file. I have compared both files and tried changing some data around with a hex editor (used WinOls to compare and edit) but...
            10-30-2023, 06:09 PM
