Crelander DS16 Dual screen BIOS Update failed recovery with CH341A
+ More Options
Posts
  • michelhadid
    • Oct 2023
    • Mexico
    Hey guys. Michel here. I´m trying to recover a Crelander DS16 Laptop (i7 10750h dual screen laptop, ZENBOOK DUO Clone).
    Laptop lost power and failed a BIOS Flash mid flash with AFUWIN/DOS. I of course made a backup beforehand, however, i can´t flash with AFUWIN/DOS now since it doesn´t boot/post anymore (black screen, fans on). I´ve read the BIOS chip (W25Q80DVSIG) with a CH341A Programmer, but AFUWIN Bios backup is 12MBytes and the CH341 read is a 1Mbyte file. I have compared both files and tried changing some data around with a hex editor (used WinOls to compare and edit) but still can´t get anything working. I uploaded the file to UefiTool but i dont understand how or what exactly i should extract/delete from the 12MByte .rom file to be able to flash and recover with the CH341A programmer. Please let me know if you can give me some tips or help with this. Thanks and have a good day!
    [URL="https://dr*********************************************KzR2lH3h/view?usp=sharing[/URL]
    • 21493
    Re: Crelander DS16 Dual screen BIOS Update failed recovery with CH341A
    Originally posted by michelhadid
    Hey guys.
    Read the rules before posting.
    • michelhadid
      • Oct 2023
      • Mexico
      Sorry about that. Zip with files attached here.
      • michelhadid
        • Oct 2023
        • Mexico
        Appreciate your guidance. Correct chip was a W25Q128JVSQ on the motherboard underside. Read with CH341A, result was the correct 16MByte file. Fixed the read by comparing and transfering missing parts from the original BIOS backup and flashed back. Worked like a charm. Running a custom/modded BIOS now with no issues. Thanks!
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • test.it
          Failed bios update on a Dell Precision 3650 Tower
          by test.it
          Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
          01-28-2025, 07:32 PM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • spechto
          Fujitsu E752 BIOS Update failed, FAN Problem after recovery.
          by spechto
          Hello together,
          to update the BIOS from Windows was a bad idea, because after the restart the update process failed and the system was dead. By programming a recovery BIOS directly in the two chips, the system was alive again. But after that procedure, the CPU Fan of the system runs with nearly 100%, without having a hot cpu. Has anyone an idea, how can I reset this? I restored the BIOS default, removed the BIOS battery and tried some other BIOS-Images ...
          Martin
          06-06-2020, 06:06 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
