LG 43UK6200PLA - yellowish picture
  • nomoresonys
    • 12276
    • U.S.
    Re: LG 43UK6200PLA - yellowish picture
    Originally posted by tomislav4545
    When I did the half screen test it did flicker on the faulty side. Energy saving was on and when I switched it off it only brightened the screen a bit and nothing else. It was tested without any cables just power.
    So the other side did not flicker at all, just the "faulty side"?
    • nomoresonys
      • 12276
      • U.S.
      some more there, try #2, see what you get: https://smarthomeowl.com/lg-tv-screen-flickering/
      • nomoresonys
        • 12276
        • U.S.
        another tape "solution", which most of them are: https://www.youtube.com/watch?v=3bApo5i9yv0
        • tomislav4545
          • Jul 2022
          • 11
          • Croatia
          The other side didn't flicker. I will probably leave it as is for now. When I block pins similarly to videos you shared (10-12 pins at once) the picture would be solid but discolored.
          • nomoresonys
            • 12276
            • U.S.
            it is strange, I believe this is the only tape fix I have seen on here, where the tv was left flickering.
            • tomislav4545
              • Jul 2022
              • 11
              • Croatia
              #26
              There is probably more to the solution than what I did. I'm going to leave it as is and maybe in the future try again.
              • nomoresonys
                • 12276
                • U.S.
                #27
                well at least its watchable now,
                • Storyteller12
                  • Jun 2020
                  • 625
                  I have an 86” tv of this “uk” series with similar problem.
                  If I cover pins 13-15 I get a perfect picture with no flicker at all but lose color. (Magenta) specifically.
                  If I didn’t cover pin 15 the screen flickers as you mentioned. From what I can tell there is never a perfect picture when using the tape method, One way or another the picture gets degraded somehow
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • noisykid
                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                    by noisykid
                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                    12-30-2024, 07:15 PM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • adamp91gvm
                    hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
                    by adamp91gvm
                    as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
                    09-10-2025, 12:13 PM
                  • hendue
                    BenQ 2765HT vertical lines, no picture
                    by hendue
                    I was trying to fix the monitor, which was giving me the following pictures:
                    It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                    I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                    Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                    I turned around...
                    09-09-2025, 08:27 AM
