Vizio 40” V405-H19 has backlight, no display
  • mattd1979
    • Apr 2014
    • 30
    I have a Vizio TV that I am trying to fix for a friend. The problem is when you turn it on, you get a back light but no picture. If I press the input button one time on the remote, I will hear music. I ordered and replaced the main board as well as the power board from Shop Jimmy but no change. Any ideas on what else I can try to get a picture? The TV is a couple of years old.
    Thanks in advance,
    Matt
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio 40” V405-H19 has backlight, no display
    Bad t-con
    • mattd1979
      • Apr 2014
      • 30
      Is there anything I can do at the component level to fix it? The T-CON board to LCD ribbon cables are bonded to the LCD.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need some good pictures of t-con, and other boards
        • mattd1979
          • Apr 2014
          • 30
          I have attached 4 photos. One wide shot and 3 up close shots of the T-CON board.
          • dskall
            • Oct 2016
            • 2905
            • usa
            First check your white fuse where ribbon cable comes in for 12v on both sides. I can't see other voltages with these pictures.
            • mattd1979
              • Apr 2014
              • 30
              Are you referring to the little white chip to the lower right of the connector in the photo on the T-CON board?
              • mattd1979
                • Apr 2014
                • 30
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Yes. And only need good pictures of t-con board.
                  • mattd1979
                    • Apr 2014
                    • 30
                    I tested the resistance on the fuse and it is at .02 ohms.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Do you get 12v to the fuse when tv is on?
                      • mattd1979
                        • Apr 2014
                        • 30
                        Yessir I get 12.64 volts at each end of the fuse next to the ribbon connector.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          On picture 5 you have a VGH and VGL test point you can measure.
                          You might also try disconnecting the 2 interconnect ribbon cables at picture 3 and see if you get half a picture.
                          • mattd1979
                            • Apr 2014
                            • 30
                            I recently tried disconnecting the ribbon cables as you said but it didn't make a difference. What should the voltages be on the VGH and VGL test points?
                            • mattd1979
                              • Apr 2014
                              • 30
                              Readings are the same when unit is on or off.
                              VGH = .793 V
                              VGL_AA = 1.156 V
                              VGL_GOP = 0.00 V
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                So those are bad. Maybe best thing you can do is check the brown caps for shorts.
                                • mattd1979
                                  • Apr 2014
                                  • 30
                                  Which ones are the brown caps and how do I go about testing them?
                                  • mattd1979
                                    • Apr 2014
                                    • 30
                                    The only capacitors I am familiar with are the cylindrical capacitors and I don’t see those. I see very tiny chips. Some are tan and some are dark brown that seem to vary slightly in size. Are those capacitors?
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      some of them are, look closely at the designator beside the component, if it's a cap it will start with a C.
                                      • mattd1979
                                        • Apr 2014
                                        • 30
                                        I just finished checking resistance on all of the capacitors I could find on the T-CON board and the readings ranged from 550 ohms to 30.00 k ohms.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
