42LN5300 backlight randomly blacks out
  • howardc64
    • Jun 2017
    • 632
    Have sound. tried 2 main boards with same symptom (so likely ruled out main board for sure)
    - Whenever backlight goes out, it is always recoverable by disconnect LED from PSU, test with LED tester, reconnect LED to PSU. Turn on TV. Without using LED tester, blacklight remains out.
    - When backlight is on and run white image test, shows no burnt out LEDs (see attached, uneven bright spot on the right center isn't really as visible as the pic)
    Seems pretty definitive there are weak LED(s) in the array and LED tester's gradual voltage ramp makes it work again for awhile. Thought I ask other's experiences before buying the LEDs. Thanks
  • neilc6
    • Nov 2015
    • 1550
    Re: 42LN5300 backlight randomly blacks out
    Backlight issues are almost always the LEDs themselves especially LN, LA, LB or LF series. When intermittent, the voltage can fluctuate and trip the protection circuitry. One bad LED you may not be able to see on a white screen. Just replace them all with new and turn down the backlight level on all inputs. Just picked up a 42LN5700 with cracked screen for parts. Owner said he loved the TV and replaced the backlights previously. Curious, I checked his work and he didn't do a full replacement and had 2 strips that were original and one of them had a shorted LED. He also never removed the standoffs so the reflector sheet was floating and causing shadows. https://techhometravel.com/lg-ln-ser...ed-backlights/
    • alfatv
      • Sep 2020
      • 353
      The least hassle is to replace all LED strips.
      It could be also bad contact or intermittent LED, that you need to figure it out by yourself.
      • howardc64
        • Jun 2017
        • 632
        Thanks. Will replace LED strips, test, and report back.
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • signal.quest
          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
          by signal.quest
          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
          03-17-2024, 10:14 AM
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
