Vizio M557-G0 vertical red lines
  • mightymos
    • Jun 2022
    • 9
    See attached photo for symptoms.
    Supply board produces +18V on output pins and shows no fault with ~3V on fault pin. Backlights come on.
    I replaced two 220uF capacitors on main board because plugs might have popped a little underneath (hard to tell) but no change in symptom. Main board has two UART headers which I soldered connectors onto, but do not see activity on either with scope.
    I've tried wiggling connectors around unit when powered on but no change in symptoms.
    • 12307
    • U.S.
    Re: Vizio M557-G0 vertical red lines
    make sure cables to tcon are clean aligned well and not loose fitting, and maybe test tcon voltages to make sure they're everything they should be.
      • 12307
      • U.S.
      maybe test the little caps on panel driver board for shorts or low ohms.
        • 12307
        • U.S.
        If you can bring up a menu, see if it also effects the menu display.
        • mightymos
          • Jun 2022
          • 9
          As far as I can tell I reseated cables and they seem okay.
          I can get TV to respond to button presses for power and maybe display changes when I push other buttons but no intelligible display.
          I have the 55T32-C0L board.
          The problem is I can only find one datasheet for RT7277 step down converter, though other switching regulators seem to be present. There's one other datasheet found for serial flash.
          The voltage feedback divider is a little different than datasheet and uses three resistors, two in bottom branch in series. In circuit both divider legs measure 7Kohm, so I think output voltage should be about 1.5V. It shows 1.2V on scope but isn't wildly different I guess. Might make sense that I'm just misinterpreting layout or in circuit is messing up measurements.
          There are five capacitors on Vout, in circuit they show 50 ohms across which seems low. However there's also a resistor [18A] code across them which would apparently mean 150 ohms.
          I'm possibly considering replacing tcon board from jimmy but can try other troubleshooting steps.
            • 12307
            • U.S.
            maybe check voltages of tcon, VDD, VGH, VGL, VCOM.
              • 12307
              • U.S.
              you probably already did, can test for voltage going in and coming out of tcon.
              • mightymos
                • Jun 2022
                • 9
                I finally paid attention to silkscreen and noticed labeled test points.
                AVDD 15.12 V
                VSS0 0 V
                VGHD 24.8 V
                VGH 24.8 V
                VSSG -7.9 V
                VCC 3.3 V
                V3D3 3.3 V
                0_TCON 1.8 V
                1_TCON 1.1 V
                V12 12.2 V
                • mightymos
                  • Jun 2022
                  • 9
                  Hey sorry, any of my voltage measurements in the other post seem suspect? Did I miss any measurements?
                    • 12307
                    • U.S.
                    might need more opinions but they seem ok.
                    • mightymos
                      • Jun 2022
                      • 9
                      Thanks so much for taking a look.
                        • 12307
                        • U.S.
                        well if tcon is ok, guess I would suspect the mainboard.
                        • mightymos
                          • Jun 2022
                          • 9
                          I initially ruled it out since they board seems to be getting +18V and fault line on power supply shows high level (good) (but guess that just means led drivers are okay). I'll try to check supply voltage on main board, tough without a schematic. Any advice where to start?
                            • 12307
                            • U.S.
                            mainboards can be a tricky animal, some testing there, there's lots more on youtube also:
                            https://www.youtube.com/watch?v=ocqnqmBxiqY
                              • 12307
                              • U.S.
                              have been having bad luck fixing boards lately, even powerboards.
                              • mightymos
                                • Jun 2022
                                • 9
                                Thanks for the attempt though.
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • brad2157
                                  Vizio E70-E3 Two white vertical lines
                                  by brad2157
                                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                  Replacement main board - Boots up fine, but starting...
                                  12-13-2021, 05:11 PM
                                • viking509
                                  vizio e65 e3 LED tv color vertical lines center tv only
                                  by viking509
                                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                  03-21-2023, 12:48 AM
                                • Falki
                                  Colorful LCD Vertical Lines on Samsung ue55es8090
                                  by Falki
                                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                                  A similar issue has been posted as well but also with no actual response ...
                                  08-12-2025, 04:19 AM
                                • visionbluedemon
                                  Help. Sony kd-65x85dj vertical lines
                                  by visionbluedemon
                                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                  tried blocking LC lines too, but same results
                                  is it lcd panel issue or tcon board issue?...
                                  07-25-2025, 04:56 AM
