Sharp LC70LE747 Flickering - darkening gradually to the right side
  • SmartSarah
    • Jul 2016
    • 20
    • Belgium
    #41
    Re: Sharp LC70LE747 Flickering - darkening gradually to the right side
    I'm puzzled why it remains good as soon as it starts good.
    Once running fine, I can tap on components and parts, it stays good.
    Running bad, it appears to be immune to mechanical interference like tapping or touching band wires. No impact at all.
    Ruling out connection issues is too soon, but not likely either.
    • nomoresonys
      • 12181
      • U.S.
      #42
      have a dumb little sceptre does similar, when it starts up, will run for as long as it's on, turn it off and won't start up again, have to mess with it, turn on and off with remote real fast and sometimes will turn on and do the same, won't tune any channels unless I use an external tuner, no response from remote or panel buttons when in bad state, thinking it must be bad memory, ie, eeprom, spi, nand, whatever is present.
      • dskall
        • Oct 2016
        • 2905
        • usa
        #43
        Seems like a bad eemc or memory. If you have a programmer that can output print information during boot up. Maybe only way to solve this.
        • SmartSarah
          • Jul 2016
          • 20
          • Belgium
          #44
          I am on to something. If I apply 12v to the PNL power supply beforehand, the unit seems to start up correctly every time. I am going to use a scope to further investigate whether this voltage reaches the level quickly enough. If I do not find immediately why the power supply fails, I will install if necessary a separate 12v power supply for PNL.
          • Civitello
            RCA RTU5540-D has flickering pixels on entire right side of display.
            by Civitello
            TL;DR: Is one side of the display showing flickering full brightness r g or b subpixels in a sparse arrangement likely to be a defective secondary board?
            Model: RCA RTU5540-D
            Problem: The right half of the display has pixels flickering, it seems like random subpixels (red, green, or blue) are being turned on at full brightness briefly.
            I have tried reseating and switching the two ribbon cables coming from the secondary board to no avail, but I did confirm that each one corresponds to 1 half of the display. I considered trying to drive the right half of the...
            05-14-2023, 05:28 PM
          • WillHoh
            Slight flickering and horizontal stripes on the right side - VX24AH Asus
            by WillHoh
            Hi, I have an Asus VX24AH monitor that suddenly went black and didn't display a logo when I switched it on. After extensive research (also thanks to this forum) I was able to get it to show a picture by disconnecting the STV (VSTB1). Unfortunately, the right side now shows horizontal stripes and it looks like every 2nd pixel row is missing.
            Can anyone help me with this? Can it still be saved? I would also appreciate links and references to literature or other information.
            Before disconnecting, the test point of VSTA1 and VSTB1 only measured 30 ohms. I therefore disconnected...
            08-26-2024, 06:45 AM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
