Slight flickering and horizontal stripes on the right side - VX24AH Asus
  • WillHoh
    • Aug 2024
    • 6
    Hi, I have an Asus VX24AH monitor that suddenly went black and didn't display a logo when I switched it on. After extensive research (also thanks to this forum) I was able to get it to show a picture by disconnecting the STV (VSTB1). Unfortunately, the right side now shows horizontal stripes and it looks like every 2nd pixel row is missing.
    Can anyone help me with this? Can it still be saved? I would also appreciate links and references to literature or other information.
    Before disconnecting, the test point of VSTA1 and VSTB1 only measured 30 ohms. I therefore disconnected VSTA1 first (without improvement) and then VSTB1 (while closing VSTA1 again at the same time). The test points now all show 30 MOhm.
    Here are a few more pictures that might help.
  • kotel studios
    Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
    by kotel studios
    Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
    In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
    08-06-2025, 02:07 AM
  • Civitello
    RCA RTU5540-D has flickering pixels on entire right side of display.
    by Civitello
    TL;DR: Is one side of the display showing flickering full brightness r g or b subpixels in a sparse arrangement likely to be a defective secondary board?
    Model: RCA RTU5540-D
    Problem: The right half of the display has pixels flickering, it seems like random subpixels (red, green, or blue) are being turned on at full brightness briefly.
    I have tried reseating and switching the two ribbon cables coming from the secondary board to no avail, but I did confirm that each one corresponds to 1 half of the display. I considered trying to drive the right half of the...
    05-14-2023, 05:28 PM
  • maksimthuk
    JVC LT-58VA6955 help repair image defect horizontal stripes
    by maksimthuk
    MODEL JVC LT-58VA6955
    MAIN 17mb170
    PENAL ves580qndp-2d-n42
    T-Con CCPD-TC575-009 V1.0
    PSU 17ips72
    There are no horizontal stripes (see photo). There is a sound of moving through the menu! Maybe someone has encountered such malfunctions?
    08-07-2024, 08:11 AM
  • Strudul
    Sharp LC-60LE741E - Horizontal Bands / Stripes
    by Strudul
    I have a strange problem that appeared suddenly on my SHARP LC-60LE741E 60” LCD television. It has 22 evenly spaced horizontal grey stripes over the entire area of the screen. The stripes only effect dim areas of an image. Blacks are still purely black, and anything brighter than 40% is unaffected. Bright outdoor scenes are fabulous. Dark low contrast scenes ... like all CGI on Netflix are unbearable. It's like your looking through dirty venetian blinds. The grey bars appear above any slightly dark colors. If you look closely, you'll see that there are white pixels mixed in with the correct...
    12-20-2022, 06:06 PM
  • kevinman
    KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
    by kevinman
    Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
    12-17-2023, 06:22 AM
