Half screen on Sharp Aquos LC-32d64u
  • acidophilus
    • Apr 2010
    • 50
    Re: Half screen on Sharp Aquos LC-32d64u
    The two ribbons going to the driver are Good. I can interchange them and it works the same. I dont know about the ribbon going to the T-con though, it is unidirectional so I can't flip it.
    • x33
      • Jan 2010
      • 37
      I think the problem is on the controller board attached to the screen itself, at the other end of those two ribbons. This will imply removing the LCD from the metal casing to get good access to the board.
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Megan0
        Sharp LC-70UD1U Half screen Normal half screen is white
        by Megan0
        My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
        Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
        Result:
        I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
        Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
        Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
        Only in the first test, where I did not
        01-19-2022, 11:20 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
