Sony KD-55X8509C fails after warmup
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    Hi, I've got a Sony set that acts weird. It works absolutely fine for 2-3 hours, then shuts down with 6 blinks. After a bit of cooldown it works again for some time. Service menu indicates backlight error, but in edge-lit TV it would be clearly visible that one or more LEDs fail.
    The person I bought the TV from replaced the power supply with no effect on the issue (he even gave me.the spare one with the TV). Main board and the TCon seem reasobably warm.
    Pics of PSU (original one) and MB attached.
    • 12276
    • U.S.
    Re: Sony KD-55X8509C fails after warmup
    need a picture of the whole back of tv as to see how everything is connected.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would heat parts of main board and see if you can locate problem.
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        https://youtu.be/uW3i_rSSwjk
        • mrsith
          • Mar 2021
          • 146
          • Wielka Brytania
          Pic attached showing how everything is connected.
          I'll try heating.
          I know how to replace the backlights, it doesn't seem like a LED strip problem as they work fine for couple of hours before the TV fails.
            • 12276
            • U.S.
            ok, have a good look the legend/map on powerboard, do any of them say bl-err?
            • mrsith
              • Mar 2021
              • 146
              • Wielka Brytania
              BL-ERR gives 2.3v with set powered off but plugged in.
                • 12276
                • U.S.
                what does it read powered up?
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  Nothing at all.
                  I've been told by 2 separate sources that the smthe LEDs tend to fail this way in this TVs. Been explained how and why and it made sense so I've boufmght replacement strips. I'll post if it solved the problem after changing and testing them.
                    • 12276
                    • U.S.
                    could be backlights and they do fail a lot but i have a feeling it isn't.
                    • mrsith
                      • Mar 2021
                      • 146
                      • Wielka Brytania
                      Apparently these backlights tend to fail this way. I had original parts to replace and I could see that old LEDs were clearly darker/oranger than new strips.
                      The TV was working fine for 5-6 hours after replacing them, looks like the job is done. Thanks a lot for your attention and advice!
                        • 12276
                        • U.S.
                        ok, glad to hear its fixed, so to be clear, when tv is working properly, the standby bl-err is 2.3, and 0 when powered up?
                        • kasfamily
                          • Aug 2014
                          • 774
                          • Russia
                          Recommendations
                          The APS-385 power supply uses two four-channel CXA3854M chips, a total of 8 channels. The outputs of the inputs FB - 19, 20, 21, 22 of each chip are supplied with a signal from current sensors consisting of three low-resistance resistors connected in parallel to a chain of transistor switches. Reduce the backlight current from 140 mA to 90 mA in each channel - remove eight 8.2 Ohm resistors in each channel.
                          • mrsith
                            • Mar 2021
                            • 146
                            • Wielka Brytania
                            To be honest I did not check bl-err voltage after replacing the LEDs, I'll try to do that if it's still in the office.
                            Great advice with resistors, thank you!
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • dkneyle
                              Sony KDL-46HX850 Can't upgrade/update firmware
                              by dkneyle
                              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                              09-25-2024, 10:44 PM
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                            • ahmedtou
                              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                              by ahmedtou
                              help me please
                              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                              I will share all the details with you, including the disc information.
                              Code:
                              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                              Current Profile: BD-R
                              Disc Information:
                              Status: Empty
                              State of Last Session: Empty
                              Erasable: No
                              Free Sectors: 12,219,392
                              Free Space: 25,025,314,816 bytes
                              Free Time: 2715:27:17 (MM:SS:FF)
                              Next
                              08-27-2025, 08:49 AM
                              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                              09-06-2024, 05:30 AM
