Sony KDL-46EX505 No T-con Voltage
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    been asked to look at a friends old Sony which turns on ok, changes channels and has backlight and volume control etc. yet just displays grey, with a few streaky lines across the screen.
    A quick test revealed that the voltage across the T-Con cable connector(CN6151) on the PSU (G2) was missing, although the 3.3v 'T-CON_On' and 'T-CON_Vcc12v' were present at the connector which links to the main board (CN6150).
    As they live some distance away I took the PSU with me to see where the problem might lie.
    I'm presuming that the 3.3v needs to be connected to both the 'POWER_On' and 'T-CON_ON' in order to for the area in question on the board to stay 'live'?
    There is not a lot of circuitry between the two connectors, with a FET and a couple of transistors after the secondary of a transformer, but my concern is whether the PSU might be damaged with no load?
    I'm not a TV tech but want to know if there is likely to be any problem if I power the board up without any load?
    Enclosing the schematic and a couple of photos of the suspect area if anyone is interested
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sony KDL-46EX505 No T-con Voltage
    As a load, you can use car incandescent lamps, then checking the power supply will be more informative
    • Diah
      • Feb 2013
      • 6440
      you are correct about how to run the PCB as stand alone to have t-con 12 and other V to MB socket... but i think you took the wrong boards with you... the issue much at MB. or T-CON or panel.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Yes. Nice one.
        Obvious really, but still didn't enter my head,
        thanks
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          You think so?
          Does the T-CON_ON signal not come to the PS board from the main board? Then surely it is the PSU board which powers the T-CON board?
          Haven't had time these last couple of days but intend to power up the PSU and see what readings come up.
          • dskall
            • Oct 2016
            • 2905
            • usa
            No you don't need a load to check unless you suspect it can't put out the required current.
            T-con are most often powered through the ldvs cable from the main to the t-con on one side of the cable.
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Thanks.
              And I'm sure that there is some power in this cable as the T-CON board gets warm.
              There is a second thicker wired cable from the PSU to the T-Con and it is this which has no power.
              Hopefully should have time today to connect it up and test it further
                • 12276
                • U.S.
                yep, when dealing with distance, always take the whole tv whenever possible.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  It always helps to have good pictures.
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    Re: Sony KDL-46EX505 How to test a T-CON board?
                    For sure, but only having the one board with me didn't help.
                    Anyway, fired up the board and the T-CON connector voltages are present and correct at 12v, so it would indeed appear that I am looking at the wrong board.
                    I'll head back up to the TV in the next few days, but are there specific voltages which can be measured on the T-CON board to confirm whether or not it is working?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      vgl, vgh, vcom, vcc's
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        Still haven't got back to the TV but considering there are a multitude of lines across a grey screen, judging by what I can find, it may be that the VDA/VSource voltage is missing.
                        If tht does turn out to be the case, any idea what might cause that to fail?
                        • iglitare
                          by iglitare
                          09-04-2025, 07:13 AM
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • thelankanguy
                          Sony KD-55X9000F TCON Issue
                          by thelankanguy
                          The TV shows a black screen with no image.
                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                          Later both ribbons were disconnected and TCON voltages were tested.
                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                          There is also a short to ground in this circled inductor.
                          Is this a TCON issue or something else ?...
                          12-13-2024, 12:27 AM
                        • bbrain
                          Sony KD-55AG9 TCON?
                          by bbrain
                          I have this problem with my Sony 55' AG9.
                          It flashes 4x.
                          I have found the service manual, and seems it is the TCON.
                          Before I buy a TCON can someone check the vid?
                          Thanks in advance!...
                          09-19-2024, 10:50 AM
                        • cagri
                          BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                          by cagri
                          I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                          PMIC: iML8940
                          There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                          Input 12v, fuse ok
                          DVDD1V2 = 1.2v
                          DVDD1V8 = 1.8v
                          DVDD3V3 = 3.3v
                          VGL = -7v
                          **VGH = -0.3v
                          **VCOM0, AVDD, HAVDD = 0v
                          SWBK1 = 3.3v
                          SW1 = 12v
                          VGH to GND resistance is 500kohm as expected
                          Readings are same after I disconnected the two cables from TCON to panel...
                          07-27-2023, 09:48 PM
