UE55F7000ST clicking on/off
  • shandy
    • May 2022
    • 15
    • England
    Samsung led tv UE55F7000ST
    having problems diagnosing this TV
    The common problem that i'm having is the relay in the power supply board clicks on and off, at same time backlight goes on and off and can briefly see the smart tv logo.
    At the moment I'm thinking it is a faulty tcon board and if i disconnect it the tv will power on and stay on with sound coming through as it would normally but no smart tv logo.
    The strange thing I found is if I leave it turned off for a long period
    of time say overnight the TV will come on as normal, then I
    start thinking maybe the tcon board is ok after all but then when
    I turn it off and on again I get the clicking on and off again.
    the PS board will click a bit faster with the main board disconnected
    and with the two backlight cables connected or disconnected so would
    that indicate something wrong with the PS Board, all capacitors look
    normal with no bulges.
    Any help of insight greatly appreciated.
    Shandy
    • 12206
    • U.S.
    Re: UE55F7000ST clicking on/off
    Check solder joints.
    • shandy
      • May 2022
      • 15
      • England
      Many thanks for your reply, I did actually look at the solder joints under magnification
      and touched some up, I should have mentioned that.
      • Diah
        • Feb 2013
        • 6398
        you have sort of test wasnt complete at explaination.
        the most things now.. disconnect the main boards from PCB, and plug it in the wall see the back light come on and stay on... or not...
        • shandy
          • May 2022
          • 15
          • England
          Many thanks for your reply!
          With the main board disconnected the power supply board clicks a bit faster
          and the backlights go on and off at the same time.
            • 12206
            • U.S.
            ok, unplug everything from powerboard backlights and all, then plug power cord in, see if clicking or anything changes.
            • shandy
              • May 2022
              • 15
              • England
              I think you maybe helping me get there!
              I unplugged all leads from power supply first time power on no clicking
              turned off and on again it clicks a bit faster still
                • 12206
                • U.S.
                so the first time nothing no click at all? second time steady clicking? did you try it again?
                • shandy
                  • May 2022
                  • 15
                  • England
                  yes that's correct it clicks every time, my guess is if i leave it overnight
                  the first power on would not click.
                  I took some voltage measurements across some caps
                  the main 400v caps were going on and off and went to 385v
                  one of the caps showed a stable 5v
                  and another I think was the 3.3 which was going on and off.
                  • Diah
                    • Feb 2013
                    • 6398
                    show us focused high resolution photo of yours PCB from up and down side.. also any Voltage print chart on it as well the BL socket chart.
                    • shandy
                      • May 2022
                      • 15
                      • England
                      Hears the photos as requested, thanks
                      oops haven't done the downside yet will do after dinner thanks
                      • Diah
                        • Feb 2013
                        • 6398
                        how about the down side of the boards.. !!!
                        • shandy
                          • May 2022
                          • 15
                          • England
                          here's the downside and another BL as the first one was a bit hidden by the sockets
                          • Diah
                            • Feb 2013
                            • 6398
                            +1
                            first you need not only check visually .. but its should clean old solder and resolver again all Transformer and relay too. start with hot area.. and always you check yours work by only plug the 2 sockets of BL to PCB and turn on.. when you have BL on and stay on you are done.
                            second you need to take all standing caps at hot area and measure its ESR , some caps leaking from down side not blowing at top.
                            • shandy
                              • May 2022
                              • 15
                              • England
                              OK, many thanks, I will take a much closer look and measure the ESR of
                              all the caps.
                                • 12206
                                • U.S.
                                also check every diode, diode mode should get a reading usually 555 or so some show more some less, then switch leads, should get l or I, report any that give a reading in both directions or shows short, check the 2 legged ones first, they have the little grey stripe, not to be confused with ferrite beads that don't have the stripe.
                                • shandy
                                  • May 2022
                                  • 15
                                  • England
                                  yes, will do that also, so far I’ve found a couple of small tantalum bead caps
                                  with in circuit ESR of 6.8 ohm while others measure 0 I will take them out and
                                  re measure out of circuit.
                                  thanks again!
                                  • shandy
                                    • May 2022
                                    • 15
                                    • England
                                    I am still looking, original problem remains
                                    tested all electrolytic caps out of circuit, they tested ok with the ESR within
                                    spec, the tantalum ones tested no ESR out of circuit.
                                    tested all power gets and the 3 schottky rectifiers out of circuit
                                    tested all smd transistors and fets they seem ok
                                    tested all transformers
                                    will do resistors next
                                    • shandy
                                      • May 2022
                                      • 15
                                      • England
                                      Well it took a while all resistors appear in spec, I am now suspecting something with the main board. I found a youtube vid of a tech that disconnected a similar Samsung PS board from the main
                                      board and that one clicked in sync with the BL leds going on and off also, he bridged two of the pins with a resistor and that kept the BL on, his socket was a bit different to mine so i’m a bit reluctant to try it.
                                      I now am getting the standby led flashing on and off 2 times with 5 repetitions every time
                                      with one of the tcon leds off
                                      https://www.badcaps.net/forum/showthread.php?t=84791 this chap had the same TV and same problems as me but not sure if he fixed it.
                                        • 12206
                                        • U.S.
                                        well since he gave no more feedback, my guess is the new tcon solved the problem.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
