Seeking for Marantz DSP firmware SR4003 or SR6003 AVR
  • aliougm
    • Oct 2021
    • 11
    • Taiwan
    Anyone can provide Marantz DSP firmware for SR4003 or SR6003 AVR ? Or where I can to get it ?
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
