RCA led46C45RQ Still no fix
  • tennno`
    • Nov 2013
    • 37
    • usa
    RCA led46C45RQ sound no pic, no power going to back lights.
    changed power board 3 times,main board 1,tested leds with led tester
    all voltage correct 5v standby from power board.mains send to power
    board all voltages com 4 shows 5v 5v grd ,leds flash 2 times then go out.
    pins at led plug Spike to 150v then drops off(leds pluged in or not)
    • 12206
    • U.S.
    Re: Still no fix
    did you do the flashlight test? shine it on the screen and hit menu look closely see if you see any text or anything.
    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
    • tennno`
      • Nov 2013
      • 37
      • usa
      Re: Still no fix
      Got the set apart putting in new back lights
      • dskall
        • Oct 2016
        • 2905
        • usa
        Re: Still no fix
        I would say you are in the right place.
        • tennno`
          • Nov 2013
          • 37
          • usa
          Re: Still no fix
          Not seeing any pic with flashlight
            • 12206
            • U.S.
            Re: Still no fix
            may be a backlight issue, check the fuse on the tcon board, see if you have about 12 volts on each side, neg meter probe to chassis ground pos to each side.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Still no fix
              If led voltage goes to 150v with or without connector plugged in you have a backlight problem. How many led's does it have? Need some board pictures and connector pictures.
                • 12206
                • U.S.
                Re: Still no fix
                so what was the results? always test new backlights before and after installation.
                • tennno`
                  • Nov 2013
                  • 37
                  • usa
                  Re: RCA led46C45RQ Still no fix
                  Rechecked new led lights found 1 bad one , replaced it all works fine.
                  Thanks guys.
                    • 12206
                    • U.S.
                    glad to hear it.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
