RCA led46C45RQ Still no fix
  • tennno`
    • Nov 2013
    • 37
    • usa
    RCA led46C45RQ sound no pic, no power going to back lights.
    changed power board 3 times,main board 1,tested leds with led tester
    all voltage correct 5v standby from power board.mains send to power
    board all voltages com 4 shows 5v 5v grd ,leds flash 2 times then go out.
    pins at led plug Spike to 150v then drops off(leds pluged in or not)
  • nomoresonys
    • 12332
    • U.S.
    Re: Still no fix
    did you do the flashlight test? shine it on the screen and hit menu look closely see if you see any text or anything.
    • tennno`
      • Nov 2013
      • 37
      • usa
      Re: Still no fix
      Got the set apart putting in new back lights
      • dskall
        • Oct 2016
        • 2905
        • usa
        Re: Still no fix
        I would say you are in the right place.
        • tennno`
          • Nov 2013
          • 37
          • usa
          Re: Still no fix
          Not seeing any pic with flashlight
          • nomoresonys
            • 12332
            • U.S.
            Re: Still no fix
            may be a backlight issue, check the fuse on the tcon board, see if you have about 12 volts on each side, neg meter probe to chassis ground pos to each side.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Still no fix
              If led voltage goes to 150v with or without connector plugged in you have a backlight problem. How many led's does it have? Need some board pictures and connector pictures.
              • nomoresonys
                • 12332
                • U.S.
                Re: Still no fix
                so what was the results? always test new backlights before and after installation.
                • tennno`
                  • Nov 2013
                  • 37
                  • usa
                  Re: RCA led46C45RQ Still no fix
                  Rechecked new led lights found 1 bad one , replaced it all works fine.
                  Thanks guys.
                  • nomoresonys
                    • 12332
                    • U.S.
                    glad to hear it.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
