LCD screen swap between UE65JS9500 and UE65JS9000
  • marekk
    • Mar 2013
    • 36
    I got UE65JS9500 with cracked screen and I wonder whether it would be possible to use LCD panel from UE65JS9000.
    I know that one connect box works for both models, TCON and control board from the TV looks the same so I'm pretty sure it will work.
    I would be very grateful if anyone with more experience would give more information about it.
    Many thanks
    Marek
  • Storyteller12
    • Jun 2020
    • 624
    Re: LCD screen swap between UE65JS9500 and UE65JS9000
    I’m almost positive it will work as long as the versions of each TV is the same. I’m in the US and I believe the only difference in models is one is curved and the other is flat.
    Just try swapping main boards instead of the panels t test.
    • marekk
      • Mar 2013
      • 36
      Both models are curved.
      I know that backlight, power supply and inverter are different.
      It's a bit of gamble as I don't have Ue65JS9000 yet. I'm thinking to buy it.
        • 12097
        • U.S.
        I would try it, not positive but i think it will work.
        • Storyteller12
          • Jun 2020
          • 624
          I looked up both models. They are similar but the frame interpolation is slightly different. 1 is 2000 PQI (picture quality index) and the other is 2400PQI. It sure that matters. It it’s the only difference I saw
          Other than that everything is the same except 1 is edge lit and the other full array
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
          • ipatch
            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
            by ipatch
            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
            08-24-2024, 02:36 PM
