Hisense 65H6570F Logo shows then turns off
  • Diah
    replied
    Re: Hisense 65H6570F Logo shows then turns off
    if the USB stick are MBR mode formasted FAT32 and the file on it in name upgrade_loader.pkg and it didnt work to have screen of upgrade prosees... mean yours TV went to shut down as it had HW issue 100% are led backlight, one or more are defect.
    Originally posted by dskall
    Also, I believe the usb needs to be 4g max.
    with hisense vidaa no problem with the usb drive size, i have 64Gb MBR mode Fat32 many hisense firmware for diffrent model on it, the one i need just to rename it to upgrade_loader.pkg
  • Diah
    replied
    Originally posted by USmechS
    It did not work Diah. It is the same as it was before.
    I do not have a 4GB USB drive to test your suggestion, dskall.
    the rename supject of the file must be 100 done. what kind of stick you have ??? stick should be MBR mode
    shoe me the properties of yours usb stick and the file inside it
  • USmechS
    replied
  • dskall
    replied
  • USmechS
    replied
    Thanks Diah, I will try it tonight and report the outcome
  • Diah
    replied
    Hello everybody,
    I had this Hisense TV since November 2019
    rename the file from ( upgrade_loader_no_tvcertificate.pkg ) to upgrade_loader.pkg and start with point 7.
    be sure yours PC showing the file extension to avoid written double .pkg.pkg
  • USmechS
    started a topic Hisense 65H6570F Logo shows then turns off
    Hello everybody,
    I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
    Things I have done:
    A. Plug it off and on.
    B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
    C. Contacted the customer service, They sent me a firmware update, with the file name:
    The zip file has this name, if it is of any value:
    65H6570F_65A6101EU_L0424
    and these instructions:
    1. Follow the link above and download the file, [ ].zip. The file will be compressed,
    so using a built-in or downloaded (i.e. Winzip) unzipping software, extract all files.
    2. Locate the file .pkg. Copy and paste this file into an EMPTY FAT32 formatted USB Stick.
    a. Please ensure that NOTHING ELSE is on the USB, ONLY the.pkg file.
    b. DO NOT CHANGE OR RENAME THE .pkg FILE!
    3. Safely Eject the USB from your PC by right clicking on the USB(on your Desktop or in your My Computer)
    and selecting Eject , then unplug the USB from your PC.
    4. Turn OFF the TV.
    5. Plug the USB in to the TV s top most USB port(located on the rear of the TV).
    6. Please unplug TV from wall and plug back in.
    7. Press and hold the POWER button on the TV Remote Control,
    once you see Software updating appear on the screen you may RELEASE the power button.
    8. Please wait and let the Software Update process finish.
    a. The Software Update Process will complete without any further user interaction.
    b. The Process should take between 5-8 minutes.
    c. Please DO NOT turn OFF the TV during this process.
    9. When the update is complete, the Software updating Screen will disappear
    and the TV will come up as it normally does.
    10. Remove the USB from the back of the TV.
    I have followed it, the stage 7 does not happen. The TV shows flashing purple line sections on the left of the screen. It turns off and on doing the same thing as long as I hold the power button.
    D. I have kept pushing the power button on the remote as I plug it in, no difference.
    E. Put the USB drive on the other port, no difference.
    F. Contacted customer service again, they said change both the power board and the logic board.
    I have access to a multimeter, soldering iron, and possibly an oscilloscope. I can do some electronics repairs but nothing too crazy. I appreciate any and all suggestions.
    Thank y'all,
    Manny
  • taslan
    Surface 7 Pro wont boot, shows Logo and immediately turns off
    by taslan
    as stated in the title, my surface 7 pro wont boot anymore.
    When i press the power button it shows the square windows logo for a second and immediately turtns off again.
    I dont even have a chance to get into bios or boot from usb.
    While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
    I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
    Bought it directly from microsoft and used it now and then and only...
    01-16-2025, 01:25 AM
  • frannyjunk
    Hisense 40H4F no backlight but turns off after splash screen
    by frannyjunk
    So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
    TIA.
    09-24-2025, 10:59 AM
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
  • IIOSOH
    46PFL5507K/12 - Shows a "Hourglass" logo then turns off the backlight - No sound
    by IIOSOH
    I'm trying to fix a Philips TV [46PFL5507K/12] for a friend. A few seconds after turning it "ON" a hourglass appears and stays on the screen for around a second, then the screen goes black again, there is no picture nor sound when i connect via HDMI to my PC.
    I've opened it up and took a few measurements, but i can't seem to find the correct schematic for this exact model. The official service manual has detailed schematics and info for pretty much every other TV from the series but just some generic information about this exact part number so i measured...
    04-02-2022, 12:43 PM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
