Pioneer PDP-427XD TV part Cap details Pls'
  • BoB4js
    • Apr 2022
    • 3
    • Scotland
    I have a Pioneer PDP-427XD TV, not many hours on it. Bought second hand, I think it must have been a TV used in a meeting room, as it was like new when we got it. No manual, but worked out most of it.
    The Problem I have now is it went out with a crack noise, then a blinking LED, if I remember it had 6 flashes.
    I had a look and after a bit of hunting around (very frustrating as TV shuts down after a few seconds), I found a Capacitor on the Scan Assy Top Board had cracked and tried its best to meld down. Now, as it happens, I can get to this capacitor, but not the others on the same board. There are others the same, but it means removing loads of screws and shielding to get to them. A bit of a nightmare! However, I have found out the capacitor number and part number, though not type, voltage etc.
    Can anyone help with this? Details below:
    FROM BOAD: Scan B Assy Top Board:
    Capacitor No: C2741. (I think 2751 and maybe all between may be the same value).
    Part Number: ACG1125.
    If I could find out the details of this capacitor, I can change it.
    I did contact Pioneer UK, but no reply!
    I think it is worth replacing the capacitor, the TV has an excellent picture.
    I might be able to get a board, but I think the TV would need to be set up again, I don't have the equipment.
    If anyone knows Capacitor type, value, Surface mount, no details on capacitor or board except C2741.
    The capacitor has a crack and as soon as it arcs the TV power supply shuts down and blinks. So I think if I replace it the TV should run, if it has another fault it will go to TV heaven.
    Thanks for any help in advance.
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Re: Pioneer PDP-427XD TV part Cap details Pls'
    C2741, c2751 - acg1125 - (0.22 µf/250 v)
    • BoB4js
      • Apr 2022
      • 3
      • Scotland
      Thank-you lotas, very much appreciated.
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • grimacelord
        Pioneer VXS-D902S Reciever - Filter Capacitor Question
        by grimacelord
        I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
        I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
        I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
        01-12-2023, 02:40 PM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • chth96
        If I replace with inferior capacitor, Is it No harm to other IC components at all?
        by chth96
        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
        I know that these capacitor will not last as long as nichicon capacitor...
        12-22-2023, 04:34 AM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
