Vizio D55-F2 audio problem
  • handsworth
    • Oct 2015
    • 174
    I got this for free because the recycle place said it didn't work. Got it home and seemed to work fine. It played great as I kept it on for about 4 hours trying to see whats wrong. Shut it off and then immediately turned it back on. Guess what? No sound. Tried the same scenario with different sources and got the same result. Only get sound again if I let the tv sit for a while. I'm suspecting main board but wanted a few suggestions before I purchase another one. Thanks in advance
  • nomoresonys
    • 12272
    • U.S.
    Re: Vizio D55-F2 audio problem
    a few things to try if you didn't already, tv unplugged press and hold power button on tv for 30 seconds, factory reset, firmware update, did you see if the external speaker or headphone part works if equipped, that is during the fault condition?
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • falcontech
      MOTU TRAVELER MK3 AUDIO PROBLEM
      by falcontech
      Good Afternoon
      I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
      01-24-2025, 08:47 AM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • tk5ep
      Stanmore JN3018 audio problem help request
      by tk5ep
      I've been given a non working Stanmore JN3018 loudspeaker.
      The power supply part works normally, I have all voltages on all chips. But no sound is coming out.
      I tried to track the audio signal from the inputs to the loudspeaker.
      Unfortunately, it's not easy, as most signals are PWM. But the analog part is working, and I can track the PWM at the inputs of the TAS5508c.
      At the TAS5508c output, I only have pulses which I can find on the input of the final amplifier TAS5342a.
      Can somebody help me to resolve this problem ?
      02-16-2025, 10:46 AM
    • rajbot
      No Power problem with Vizio E60-E3
      by rajbot
      Hi all:
      I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
      I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
      On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
      03-22-2023, 08:09 AM
