TV LG 32LG600 turns on when you want
  • diegito11
    • Jul 2016
    • 94
    • España
    It enters a loop to try to turn on where sometimes after "x" time it manages to turn on or most of the time it fails to turn on continuing with the loop. The loop is always: 1st The red button alternates with the white color, this is normal. 2º About 5 seconds with the black screen and then the screen starts to shine, this is normal. 3º The screen stays black and I immediately start with step 1 and so on, the normal thing is that after the brightness of step 2º the image appears. If I leave it unplugged for several hours, it turns on without problems, but if I turn it off and want to turn it on again, it returns to the protection loop. The power supply is the LGP32-ATN model. I don't know what other type of protection system this television has. It has happened to me twice now that it has entered the loop while it is on. I leave the link of a video that is worth more than a thousand words and images, if it is not allowed please let me know.
    https://www.youtube.com/watch?v=_IBXpivEZWk
    say that I have checked welds and it is still the same, I think it looks like a T-con
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: TV LG 32LG600 turns on when you want
    I think you have a power supply problem. Maybe bad capacitor.
    • diegito11
      • Jul 2016
      • 94
      • España
      I have checked all the power supply capacitors and they are all correct. This TV is giving me quite a few headaches.
      • nomoresonys
        • 12307
        • U.S.
        probably a problem on the mainboard.
        • diegito11
          • Jul 2016
          • 94
          • España
          https://www.youtube.com/watch?v=0o5D9SVTDOo
          could this be the problem?
          apparently it is a common problem in these LG because I have already been able to verify it in several forums on the internet but they do not find the solution.
          • dskall
            • Oct 2016
            • 2905
            • usa
            They gave you the solution. It is bad contacts on processor and needs to be reflowed. Or processor is bad.
            • diegito11
              • Jul 2016
              • 94
              • España
              Could you do a little reflow and see how long I can last?
              How much would this type of processor support less than 248º?
              • diegito11
                • Jul 2016
                • 94
                • España
                Because of bios you don't think it's right?
                • fauzanmint
                  Chromebook can't turn on without a normal battery
                  by fauzanmint
                  I have several chromebook laptops, the problem is that the battery is damaged. I tried to buy 1 and I tried on all off units can turn on normaally. This means the Chromebook can't turn on without a normal battery.
                  is there a way to turn on a chromebook without a battery with bios or hardware modifications?​
                  10-12-2024, 02:36 AM
                • waakye
                  ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                  by waakye
                  I was giving this ASUS ROG G750JM that exhibit the following behavior:
                  When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                  My issue is the laptop doesn't stay on for a long time and turn itself off.
                  Any lead on how to resolve this will be appreciated.
                  I cannot boot in windows and no liquid damage.
                  Thanks in advance.
                  09-13-2024, 08:10 PM
                • reessi
                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                  by reessi
                  Hello:
                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                  I started on the ACER:
                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                  10-29-2024, 11:31 AM
                • melvinvdb
                  Lenovo y520-15ikbm most of the time doesn't turn on
                  by melvinvdb
                  I've repaired a few laptops in my life but this time my own laptop died😂.
                  Funny enough this one is a bit tough on me.
                  It doesn't turn on (most of the time).
                  Model: Lenovo y520-15ikbm (NM-391).
                  The only way to make it turn on is:
                  1) unplug battery + charger + rtc (seems irrelevant)
                  2) wait a minute
                  3) plug battery/charger in
                  4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
                  5) when it turns on it also displays POST...
                  08-15-2024, 12:28 PM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
