LG 42CS570 TV turns off and on and off and on and...
  • JT2
    • Mar 2022
    I have an LG 42CS570, LCD TV.
    Does this problem sound familiar to anyone?
    When the TV is on and is not getting any signal, everything seems fine. Light is on. Controls work. Screensaver does its thing. I can turn it on and off as desired. There's absolutely no problem with the image.
    When the TV is getting a signal, it turns itself off and on and off and on and off and on and off.... I have to unplug it to make it stop. (It never spontaneously turns itself on out of the blue.)
    This originally started as an occasional problem with an Apple TV plugged into it and it's gotten progressively worse over the last year. It would turn off and then on, and a little while later, it would turn off and then on, and so on. It would happen in the same place in the program if I started it over, so I thought it might be a buffering problem. This is not a smart TV, so the menu options that I found online for fixing buffering problems don't exist.
    The problem became more frequent. Then the cycle became more immediate, so it no longer worked for a while between off-on's. Once it started it was just off-on-off-on-etc.
    Then it started doing it with the blu-ray player, too. That's how I know it's not the Apple TV.
    Then the problem started almost immediately upon turning on any input, so it doesn't work at all for any length of time while there's an input. (It's still totally fine on its own.)
    I tried leaving it unplugged overnight with no effect. I tried leaving it unplugged for a couple months, and it was ok for maybe half an hour.
    I tried putting new batteries in the remote. I tried taking the batteries out of the remote.
    I tried all the hints about turning off the TV's timers, energy savings, and simplink (HDMI-CEC) settings. I reset every setting.
    I tried every combination I could think of with different inputs, swapping HDMI ports, swapping cables.
    I tried it plugged into the wall, in different outlets, and plugged into the power strip.
    LG said to do a hard reset and gave me instructions. Unplug for a while, hold the power button down. This worked for a couple of days, and now it's back to being entirely non-functional whenever there's an input. That worked once.
    Hard reset no longer has any effect.
    At that point I called my brother to look at it (he fixes computers). He didn't see anything obviously wrong on any of the boards, but said the power supply was making a noise. He said he checked the wires and connections, too.
    He thinks the power supply is going bad and it can't handle the extra draw when the control board is trying to do more than the minimum of being on and displaying menus. So the power cuts out or drops momentarily, or maybe the power it gives isn't enough, and the control board says "oh! I lost power, I'll turn off...but here it is again, I'll turn on..."
    The light up power button on the front is always either blue-on or red-off, so it's not like a powerout. It's like turning off on purpose then turning on on purpose, and so on.
    My brother said I should replace the power supply first. Then if that doesn't solve the problem, I should replace the control board.
    So. Have any of you seen a TV do this before? Does it sound like the power supply? It's only the initial resemblance to buffering that makes me wonder. But perhaps a power issue was making it do that?
    Many thanks.
  • Diah
    • Feb 2013
    • 6614
    Re: LG 42CS570 TV turns off and on and off and on and...
    if the PCB cant handle pull up currents with full operation and this is not the case as i think... you can bring the lamp light down and see if it remain long on..
    but my first thought went to software problem.. thought long time of working years age of ithe firmware to handle apple TV or any other new platform devices.. so i suggest to make hard reset by in_stop command or by inter service menu initial the eeprom chip , then after the hard reset turn off function of CEC & Auto Off/Auto Sleep .
    • nomoresonys
      • 12331
      • U.S.
      maybe also check the solder joints on powerboard, just to be sure they are all good, can google images of bad joints if needed.
      • JT2
        • Mar 2022
        Diah:
        So you think it may stay on longer before the problem starts if I turn the power setting down all the way? I can try that.
        The sleep and CEC settings are both off.
        The Apple TV is the same vintage as the TV. Perhaps I can reset that to factory settings, though I think it might auto update right back to where it is. I'll take a look.
        • JT2
          • Mar 2022
          nomoresonys:
          My brother said he took the boards off and checked both sides and didn't see anything obviously damaged.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Is this just with hdmi? How about other inputs or over the air stations?.
            • Stanley1843
              PS3 Slim Turns OFF Immediately After Turning ON
              by Stanley1843
              Hi, my PS3 Slim (CECH-3003A) when I connected to 230V the PS3 the indicator of the switch is red and after pressing it the is green (fan spins) for only 10 seconds and then completely off. Some times also is completely off when I connected to 230V.
              On the CN101 connector at the 5VSB pin I measure 0V.
              Without the CN101 connector pluged in the PS3 board (on the fly) I am measuring 5V on the 5VSB on the power supply side.
              On the 5VSB in respect to ground I am measuring 6 Ohm resistance. There is any schematic to find which ICs supplied from 5VSB or any suggestions where l have to...
              12-30-2024, 02:56 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
              High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
              I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
              This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
              If it cycling on and off constantly then it is the bulb itself that is the issue
              06-03-2023, 05:24 PM
