Wintel Win1X STB
  • japlytic
    • Oct 2005
    • 2086
    Wintel Win1X STB
    Two days ago, I repaired a Wintel Win1X digital terrestial STB for my class instructor at TAFE, which he told me the box took about 20 minutes to start up. Looking through the vents when I was at TAFE, I saw two bulging capacitors (which were C8 and C10).
    I did not take my changes of powering up the box before replacing the electrolytics, for the possibity of overvoltages caused my heavy loading of a rail through bad electrolytics.
    All of the electrolytics were replaced with Nippon Chemi-Con SXE series, except for C2, with a Nippon Chemi-Con KMH Series (Nippon Chemi-Con is my first choice in quality Japanese electrolytics... been in business since 1931! : )
    As a good measure, I decided to make the following changes, board space permitting:
    C8 (1000uF 16V) with 2200uF 16V
    C9-C10-C11 (470uF 16V) with 2200uF 16V
    C12 (220uF 16V) with 1000uF 16V
    C13-C14 (220uF 16V) with 470uF 25V
    C15-C16 (100uF 35V) with 470uF 35V
    C17-C18 (47uF 50V) with 220uF 50V
    C4 (10uF 50V) with 100uF 50V
    and finally, C2 (68uF 400V) with 220uF 400V, as another good measure...
    Now the box powers on within seconds, and is working perfectly, and also under bench testing, which shows no further problems.
    The electrolytics replaced were brand "DM", ZL series, and two with a "S" logo, SK and EX series. Does anyone know about them?
    It was too bad that a German manufacturer was let down with bad electrolytics...
  • arneson
    • Sep 2005
    • 1267
    Re: Wintel Win1X STB
    http://www.epassives.com/s.nl/sc.2/category.2097/.f
    This is close but can't tell. Good job with repair. On this site it's
    interesting that right after temperature rating is the 2000 hr spec.
    That looks like expected life.
    Jim
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      That would be 2000 hours at full rated ripple current and at max. rated temperature. If you check a datasheet, you'll see that mfrs publish multipliers that take into account lower currents and temperatures.
      PeteS in CA
      • Delicieuxz
        I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
        by Delicieuxz
        I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
        Here's an audio clip of the sound coming from my speakers:
        https://vocaroo.com/16HaryHwTx78
        I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
        11-15-2023, 09:50 PM
      • Physios
        Large vs small electrolytics reliability
        by Physios
        Goodmorning.
        I have a curiosity: can low voltage/capacity electrolytic capacitors (e.g. 16V/47uf) last longer than high voltage / capacity ones (e.g. 63V/2200uf)?
        I ask because many threads indicate a life of electrolytics that does not go beyond 15 years (it seems to me that Panasonic has written something in its documents), but I have several musical instruments bought in 1980 that work perfectly: they have inside them many small electrolytics. I tried asking an electrical engineering friend to unsolder some and measure them, and these were incredibly within spec....
        03-08-2021, 01:28 AM
      • Alfieh
        NAD C320BEE repair possibly bad capacitors
        by Alfieh
        hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
        recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
        11-19-2024, 04:55 PM
      • Crystaleyes
        What are the 'actual' effects of old electrolytics in a vintage radio?
        by Crystaleyes
        Hi all.
        Just trying to get a better understanding of electronics in general, and although I know that it can be general practice to replace any electrolytics in vintage gear, I was wondering 'what' are the effects from these failed components?
        I can see that a shorted cap acts as a short circuit and therefore a power drain, but what else might it cause?
        Similarly, an open cap won't be smoothing any signals but is there anything else?
        I'm sure this is basic 101 but I'm not at school, so just learning as I blow things up...
        07-05-2022, 06:41 PM
      • Exim
        Yamaha YST-MS25 amp board recap: replace small electrolytics with different type?
        by Exim
        Hi there, I'm working on the 25W amp board of a Yamaha YST-MS25. It's 20yrs old.
        Since a few months the volume on the left channel is way too low. It turned out that - compared to the intended use and the former price tag of this thing - they put solid stuff into it. So I decided it's worth a recap.
        The board uses two amp ICs on opposite sites of the board. Both ICs are connected to the same heatsink. The heatsink unfortunately is a bridge-like construction that covers almost all other components, including the majority of the caps (pictures and schematics below).
        10-31-2018, 04:11 PM
