Lg 42lc7d
  • Jackching
    • May 2017
    • 127
    Lg 42lc7d
    So i have a really old 42lc7d tv which had the caps replaced and the hdmi ports repaired. The tv still works well. The one problem im having is when i try to use the firestick, the firestick splash screen will come up and then the screen goes black. I tried all of the resolution settings on the firestick and none worked. Im thinking it could be a problem with the handshake. I know the ports work because other devices work on them. Im thinking a firmware update might fix it but i see lg removed firmware from their site for this tv. Im wondering if there is any online database for older firmware for this model or if a software upgrade will even fix it.
  • nomoresonys
    • 12331
    • U.S.
    Re: Lg 42lc7d
    and your firestick works fine on another tv?
    • nomoresonys
      • 12331
      • U.S.
      Re: Lg 42lc7d
      had a similar issue about 6 years ago with a sony kdl, its kind of hazy now, but every time I would pick hdmi then try powering firestick the screen would blank out, like maybe the mainboard just couldn't handle that extra stress or something, tv played fine from antenna also. I didn't have an extra hdmi device to try at the time I was messing with it, I think I replaced the mainboard to fix it.
      • Jackching
        • May 2017
        • 127
        Re: Lg 42lc7d
        ya It works fine on another tv. I tried two firesticks on it actually and both did the same. Im not replacing the board. Not worth it in my opinion. It seems like after the firestick splash screen that the resolution changes and the tv cant adjust to it. Other hdmi devices work. The satellite receiver works fine.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: Lg 42lc7d
          Does firestick have usb to power it? Are you plugging it into TV?
          • Jackching
            • May 2017
            • 127
            Re: Lg 42lc7d
            Ya it has usb which goes to an adapter into a wall outlet.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Lg 42lc7d
              OK. Some tv's can't supply enough current through usb to power roku etc.
              • Jackching
                • May 2017
                • 127
                Re: Lg 42lc7d
                Ya thats why im thinking it's the handshake. I was thinking a firmware upgrade may have fixed it but it still might be too old
                • zklgfs
                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                  by zklgfs
                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                  08-11-2025, 02:14 PM
                • TheUser
                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                  by TheUser
                  Hello to everyone ,
                  This is my first post here, and i would like to share with you a small story in case you can help me.
                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                  02-10-2024, 02:07 PM
                • gurj1979
                  Ubiquiti firmware help. US-8-150W POE
                  by gurj1979
                  Hi guys.
                  I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                  Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                  So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                  Got New chip and writes good.
                  THE PROBLEM...
                  It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                  Does anyone have a Good Firmware I can have?...
                  07-22-2024, 05:13 PM
                • Slapito
                  Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                  by Slapito
                  I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                  Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                  I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                  I already downloaded the BIOS update file from msi official...
                  10-09-2025, 02:00 AM
                • wattage
                  by wattage
                  Hello Badcaps Community,
                  07-13-2025, 04:41 PM
