Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
  • 265chemic
    • Jan 2020
    • 19
    Hi All,
    I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
    My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
    Below are some photos of the issue - notice the lines appearing in various places over the black - this makes me suspect an electronics issue vs. a panel issue - happy to hear any opinions on if I should try a new T-CON board, try to investigate panel ribbons further, or something else!
    T-CON board following cleaning:
    Thankyou!!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4341
    • Italy - Milan
    Re: Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
    i would do a reflow on the tcon main ic with heatsink.. don't do it with hot air, do it on an aluminium tablet on a little kichen stove putting before flux under the chip, warm it until the chip does "the move"
    • 265chemic
      • Jan 2020
      • 19
      Thanks for the reply David! So you don't think this is likely to be a panel issue?
      I've never done a reflow (at least in no capacity more than just baking a board in an oven for some time) so a little daunting. Do you have any detailed guides you might be able to recommend?
      I believe I may have located a compatible t-con board for ~$50 also, so that could be an option if necessary.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4341
        • Italy - Milan
        don't take the spare tcon, it could be faulty, save yours, take a 20x15cm aluminium tablet 4-5mm thick, put it on a stove, remove heatsink with the help of hot air, put grease flux around chip, then warm it with air to flow under, put tcon on the tablet, turn on flame at minimum, wait many minutes until flux begin to smoke, so wait a bit then with fine pliers try to move a mm an angle of chip, if it moves and return back by itself then wait 5 sec then turn off flame and let it cool down. Now test it and if ok wash it..
        • 265chemic
          • Jan 2020
          • 19
          Thanks again Davi!! I will see if I can find some aluminum plate and get some flux grease and give it a go.
          • 265chemic
            • Jan 2020
            • 19
            Hi Davi / All,
            Unfortunately no good news - I tried a reflow but now the t-con board makes a high pitched noise from the main IC and the TV won't turn on ( fast flashing red led after backlight , as if the board isn't plugged in ).
            I did modify the procedure from what you suggested in a couple of ways though, I first tested the process on an old GPU with a aluminium block 80x50x5mm I got the IC to move and cooled off okay. I used a thermocouple to monitor temperature up to a little over 200deg C.
            For the t-con, I did it right on the glass of the hotplate as it seemed more stable. I also couldn't get the heatsink off the IC so left it in place - it seemed too much force was needed. When reflowing I was also heating from the top side with a heat gun.. maybe I overheated the IC momentarily.
            Do you have any feedback? I have ordered the replacement board.
            Thanks again for your replies
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4341
              • Italy - Milan
              Two errors, one sure, the heatsink is too heavy to left it in place, second when you reflow on top with air you run the risk of destructive popcorn effect.. don't repeag it again if the chip is not very flat.
              • 265chemic
                • Jan 2020
                • 19
                Thanks, I didn't consider the weight; I guess that might flatten solder out too much, maybe causing bridging.
                What is the 'destructive popcorn effect'?
                I don't suppose at this stage it is worth trying again?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4341
                  • Italy - Milan
                  The fried eggs is done.. end titles..
                  • 265chemic
                    • Jan 2020
                    • 19
                    A lesson for the future, that is for sure.
                    I just hope that hasn't caused issues upstream/downstream, and that the new t-con, once it arrives, resolves all issues. It is said to have been tested and is out of a unit with a cracked panel.
                    Do you think there is likely to now be other issues outside of the t-con?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4341
                      • Italy - Milan
                      i think no
                      • 265chemic
                        • Jan 2020
                        • 19
                        Glad to hear that! I will update once it arrives.
                        • 265chemic
                          • Jan 2020
                          • 19
                          Good news - replacement t-con turned up and has fixed the problem, so for anyone else that has a similar issue that was what resolved it.
                          If you try a solder reflow try to do a better job than I did!
                          Thanks again Davi for your advice!!
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4341
                            • Italy - Milan
                            Happy to hear it..
                            • Falki
                              Colorful LCD Vertical Lines on Samsung ue55es8090
                              by Falki
                              Hello there, ive recently found an older 55inch Samsung SmartTV.
                              A similar issue has been posted as well but also with no actual response ...
                              08-12-2025, 04:19 AM
                            • visionbluedemon
                              Help. Sony kd-65x85dj vertical lines
                              by visionbluedemon
                              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                              tried blocking LC lines too, but same results
                              is it lcd panel issue or tcon board issue?...
                              07-25-2025, 04:56 AM
                            • arctor
                              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                              by arctor
                              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                              04-26-2025, 05:22 AM
                            • gpo23
                              Sony KDL-40V3000 - Vertical lines
                              by gpo23
                              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                              With the new t-con the color are good but there are vertical lines on all the screen :
                              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                              Is there a way to fix the vertical lines on the new t-con ?
                              Thank you for your help
                              gpo23...
                              10-04-2023, 09:11 AM
                            • wkx
                              Samsung P2770H vertical green lines
                              by wkx
                              I have a Samsung P2770H monitor, on which I replaced the main board because it has an issue that it would restart itself every X minutes, that resolved that issue.
                              Now, a few months later I turn the pc on and find 3 1px vertical green lines on the monitor, the lines wont show up on a screenshot. Does the same with dvi or hdmi.
                              I opened it up and made sure the panel connection to the board wasn't loose and the flat cable looks ok. Pressing the connectors while the monitor is on sometimes changes the line colors from green to blue or yellow, but the lines are always...
                              04-10-2020, 11:54 AM
