Cable coax splitters
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    well, welcome to wiring hell on mona vista court.
    anyway, we just had Insight come over and hook up our cable internet/tv. they had to shut down half of the main road and run a wire across the street and down the block since the previous owners had a dish.
    anyway, i had a 4 way splitter in the basement, a GE 5-900mhz. they took it out and replaced it with a butt splice, essentially a one way splitter.
    i was eventually going to run additional lines in the house... but would my splitter work for digital cable/internet?
    my original planned config
    main box:
    -wire to attic bedroom (pre-existing)
    --cable modem
    --cable box for my tv tuner card
    -wire to 4-way (pre-existing)
    --family room (pre-existing)
    --basement TV #1 (fitness room)
    --basement TV #2 (laundry room/my server room)
    --parent's room
    if the splitter is a bust, i might just use 2 two-way splitters; one for my room (the modem will be on an 8" cable from the splitter), one so the fitness room has TV (a man thing...)
    sigpic
    (Insert witty quote here)
  • bluto
    • Oct 2007
    • 560
    Re: Cable coax splitters
    Didn't the cable co make sure that the devices you currently have were working before they left? I count a total of six devices that you want hooked up (or seven-fitness room?). Ideally you would use an amplified splitter like this: http://www.smarthome.com/7750-8/Ampl...PIA-III/p.aspx to connect all of your devices. But this would also require pulling wires from each location back to the splitter.
    Is there a splitter in the main box? If there is I assume that it is a 2-way with one wire going to the attic bedroom and the other going to the '4-way'. The cable modem and digital box in the attic bedroom will probably get enough signal with your proposed splitter in the attic bedroom. The only problem could be if the return signal for the cable modem and digital box can't make it back through the splitters (if they are substandard, bad crimps, bad cable, etc.).
    The devices hanging off the 4-way are another story. If they are just analog tvs for basic cable (or expanded basic), they should be fine (there will be some signal loss but the will just cause varying amounts of static in the picture). If there are digital boxes involved, there may be issues with too much signal loss due to all of those splits and no amplification.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      yeah, but only 2 exist right now, we barely moved in last weekend.
      the main box has a 2-way in it, one to upstairs, one to the family room. reason is there were 2 previous satellite locations, un-connected. the line to the family room was originally a butt splice, i swapped for a splitter, they put in fresh connectors and a new butt-splice. all the current lines are rg-6.
      right now, we have the modem in the attic and a tv in the family room. thats all. all crimps are good. i will probably buy 2 2-way splitters, one for the attic (so we have both a modem and a cable box), one for the basement (so the family room has maintained connection and the fitness room has a TV).
      by the way, that was only part 1 of three of the wiring hell. part two is the mess of 120v-wiring; we have rooms with a mix of duplex romex and plastic grounded romex, a dryer hookup with no outlet even close to it, and switches wired wrong. my family will have an eletrician do it as i do not have the time or the expertise to do it right.
      part 3: cat5 fun- whatever dumbass previously occupied this place decided to run a cat5 line form a bedroom to the basement. well, he ran it to a room with no grounded outlets. he must have been pushing cheater plugs... anyway, i installed an 8 port 10/100 hub in the basement, ran a line to where my server will be, and will run a line to my room in the attic. the pre-existing line will be used as that will be my parent's computer room.
      however, the other two hells i have covered, its this cable part that had me stumped. i will buy the proper splitters and more rg-6 cable, and finish the job.
      sound good?
      sigpic
      • Krankshaft
        • Jan 2007
        • 2328
        It depends on your signal strength first off you want the cable modem as close to the service drop as possible. Ideally at the first splitter same goes for any digital cable boxes they are VERY sensitive to signal strength fluctuations.
        Stay away from 4 way splitters 3 way minimum (and only 1 of them at the service drop if anywhere) if you're not working with an amplifier.
        Also if you have any signal strength problems like the cable box is pixelating or analog TVs have snow you need an amp.
        Signal strength varies from place to place the best you can do is keep splits to a minimum and see what happens. If you have signal problems you'll need to install an amp.
        I use Electroline Dropamps they're what the cable companies use and they're the best IMO. They don't screw around with digital signals for cable boxes like the cheaper ones do. You can get them for around 35 bucks shipped on e-bay.
        Also never hook the cable modem line into the amp while ok for digital boxes and TVs too much signal strength can actually cause problems and slow down your Internet connection. Signal strength at the first split should be fine for the modem.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          my new plan:
          mainbox:
          -attic line
          --modem (short 8" cable after split)
          --cable box
          -basement line
          --family room cable box
          -- weight/fitness room OR parent's bedroom cable box.
          there. sound good?
          sigpic
          • Krankshaft
            • Jan 2007
            • 2328
            Yup go for it. That's your best bet.
            • tmwalsh
              • Jan 2009
              • 119
              Don't forget there is such a critter as a 'tap' that will allow access for devices very close to the 'split' that leaves the majority of the signal strength intact. That way, when you have a home-run to the attic, and a short run to the workout room, you can tap the cable for the workout room, and send the rest up to the attic at a higher strength than a full split.
              If you have on-demand type programming, you want to make sure you have two-way splitters/taps on the signal path leading from the cable entry point{demarc} to the cable box.
              tom
              • Krankshaft
                • Jan 2007
                • 2328
                If signal strength is that bad just get an amplifier they're pretty cheap and only run on a few milliamps of electricity.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  the attic line and the workout room only converge at the main box outside the house. the family room and the workout room converge at a splice in the basement. the attic is on its own for a reason; it supplies the line for the modem. signal strength should not be an issue here.
                  sigpic
                  • Kezi Gamer
                    Marshall stanmore multi room
                    by Kezi Gamer
                    Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                    03-24-2025, 08:37 AM
                  • tmcw
                    VESA EVC to VGA splitter cable
                    by tmcw
                    I found this splitter cable a while back, just got a chance to look at it now, and wondering what it might have been used for. Had a bit of trouble finding out initially what it was, main block that looks like a male DVI connector, split to 2 female VGA connectors.
                    The main block that looks like a DVI connector is actually a VESA EVC male connector, best concise info here:
                    http://www.interfacebus.com/Design_E...or_Pinout.html
                    Pin 13 on the EVC connector is missing, so maybe removed for keying to some particular graphics card?
                    Never came...
                    03-26-2024, 06:26 AM
                  • SluggerB
                    2 LG TV's in same room, one remote turns both on or off ...
                    by SluggerB
                    I have 2 LG TV's in a room. It seems the power button is the only IR button on the remote, since pressing the power button on either remote turns on/off both TV's. Once turned on, the remotes only work on their respective TV's (that is a setting I set on each, I gave each it's own ID)
                    I have "solved" the issue by putting electrical tape over most of the sensor on front of the TV's so they dont pick up the other remote's signal, but I was wondering of there was a more elegant electrical fix that could be done on the board of the remote and/or TV to make the remotes...
                    05-22-2022, 02:27 PM
                  • Dannyx
                    UART (serial ?) splitter ?
                    by Dannyx
                    Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
                    The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
                    The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
                    08-18-2023, 03:21 PM
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
