Insignia NS58DF620NA20 - have backlight but no picture
  • Daveleone
    • Apr 2016
    • 267
    Hi all! I have an Insignia NS58DF620NA20 TV here. When plugged in the power button illuminates blue. If I press the power button, the backlights turn on, but there is no picture. I can turn the TV on and off via the remote.
    How can I check whether the problem is the t-con or the main board? Is there a way to test the t-con board independently of the main board on this set (eg. bring up a color-cycling test pattern)?
    Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Insignia NS58DF620NA20 - have backlight but no picture
    First is to check if you have 12v at your t-con. It's labeled near connector
    • neilc6
      • Nov 2015
      • 1550
      Tcon is first suspect with backlight but no video. Connect one side at a time between the tcon and panel to see if one side has an image.
      • Daveleone
        • Apr 2016
        • 267
        Checked the test point. 12v present.
        Ok, I tried this. If I disconnect the right ribbon, I still get a black screen. If I disconnect the left ribbon, I get half white / half black screen (see pic).
        Another note: The TV will turn on and off with the remote. I tried pressing the different remote buttons (home, Netflix, etc) button to see if I could get anything on the screen in all 3 cases (both tcon ribbons connected, left disconnected, right disconnected) and resulted in no change. I either had fully black screen or the half white/half black as noted above.
        • Daveleone
          • Apr 2016
          • 267
          What do you guys think? Next steps?
          • dskall
            • Oct 2016
            • 2905
            • usa
            About the only way to test is to check for data coming out of main board. Or try heating up mainboard processor then plugging it in and see if it comes on. If not I would try another t-con.
            • MZorola
              • Mar 2022
              • 4
              Any luck? I have a similar issue. I switched tcot boards but no luck. I check power at tcot and get 12v. I suspect the lcd panel but don't know how to check for sure.
              • neilc6
                • Nov 2015
                • 1550
                If one side at a time does not produce an image, it is worth trying to replace the tcon.
                • Daveleone
                  • Apr 2016
                  • 267
                  Just an update on this.
                  - I tried a replacement T-Con and it did not fix the problem.
                  - I tried 3 replacement main boards and they did not fix the problem.
                  At this point I'm thinking the main board is not the problem since 3 replacement boards all exhibited the same problem (I could see 1 replacement being bad, but not 3). So now I'm thinking either 1) I got a bad replacement T-Con, or 2) The panel itself is hosed.
                  I noticed when the TV is powering on, there's a green LED on the T-Con that flashes on for a brief moment and then stays off.
                  Thoughts?
                  • howardc64
                    • Jun 2017
                    • 626
                    Thoughts?
                    screen 1/2 white with left ribbon disconnected likely suggest left panel edge board is problem location. A few different options
                    - Cut a 10mm wide thin paper to block off some t-con pins. Try different locations on the left ribbon connector and see if get partial image.
                    - Inspect the gold color edge board to panel flex and the the long narrow chip soldered onto it for any damage.
                    - Check the left panel edge boards caps for shorts.
                    - Probe some voltages on the left panel edge board with and without left ribbon connected. See whats different and give you a source to search.
                    In general, you want to see VGH (15-30v) VGL (-7 to -15v) VADD (7-15v) voltages. These voltages are specific to the panel but generally in these range. If you don't see any voltage like this, there is likely some short pulling them down.
                    Fixed an LG with sound, backlight, no image recently. Post #18 is an outline of the process. Need to dig into panel edge boards if t-con+main aren't the issues (you've tried 2 boards with same symptom)
                    https://www.badcaps.net/forum/showthread.php?t=116761
                      • 12184
                      • U.S.
                      Maybe it needs firmware update/pair, as is the case many times when the mainboard and tcon are not changed with a matching set.
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • shelby5041
                        Samsung LCD TV no picture backlight on no 12v at tcon
                        by shelby5041
                        hi
                        i have a samsung lcd tv
                        it powers on with sound and backlight but no picture
                        all voltages from PS are good 12v 3.3v and 5v
                        whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                        i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                        no 12v at the tcon fuse
                        i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                        the odds of having 2...
                        10-08-2021, 08:21 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • Fly_Among_Stars
                        VIZIO E70-E3 Half picture with half TCON
                        by Fly_Among_Stars
                        I have a VIZIO E70-E3.
                        Symptoms: Black screen, no picture, but LED backlights are working.
                        I probed the power board and voltages are as listed on the board.
                        Main board appears fine, too.
                        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                        There are two separate ribbon cables feeding the LCD.
                        If both are connected, the screen is black.
                        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                        04-24-2023, 08:20 PM
