Trying to fix LCD samsung LE32A330J1 tv, half screen with red tint
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Trying to fix LCD samsung tv, half screen with red tint
    try reflowing the ic
    • dskall
      • Oct 2016
      • 2905
      • usa
      Re: Trying to fix LCD samsung LE32A330J1 tv, half screen with red tint
      Make sure you have no shorts between legs of chip. You also might want to go through and read all the Gm1- all Gm test points on t-con in numbered order.
      • RedKazl
        • Feb 2022
        • 11
        • Lithuania
        Ok I'll have a look into the thing you call "reflowing the ic". No shorts are between legs of chip already checked, there is contact everywhere. I already went through all Gm points and everything seemed fine just that the last one showed 0 voltage which was weird to me and I don't know if it should be like that.
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          just add flux and hot air to reflow it .
          • dskall
            • Oct 2016
            • 2905
            • usa
            All should have a voltage and they should be in ascending or descending order depending on which way they are checked.
            • RedKazl
              • Feb 2022
              • 11
              • Lithuania
              #26
              Maybe I measured it wrong, but yes all had voltage in descending order except the last one, ill check again and try to reflow it on wednesday or at the weekend
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Tom C
                Samsung QN55Q70AAFXZA Half Screen Dim
                by Tom C
                I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                Any suggestions would be appreciated.
                thanks.
                09-19-2024, 07:22 PM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • Ifixstuff9
                LG 49UF6400 tint on half of screen + no OSD?
                by Ifixstuff9
                I have a LG 49UF6400 with two issues. The first is a colored tint on the left side of the screen. The color of the tint depends, but I've seen red, green, and purple so far. I can see a normal image behind the tint as shown in the photos. The tinted side flashes rapidly between "normal" and "tinted"
                I suspected either the panel or the TCON, so I tested the TV with one of the panel cables disconnected. With the left side unplugged, the left half of the screen is white and the right is black. With the right unplugged, the left has vertical bars and...
                05-30-2020, 04:09 PM
