Sony kd 65s8505c problem
  • mermel
    • Nov 2016
    • 17
    Hi ... I have the title tv with the following defect: it starts and after apx 30 seconds it stops (without giving error code in led)
    I'm attaching a faulty video
    https://vimeo.com/672665401
    If anyone has ever encountered this defect, they can give me a solution.I measured the voltages from the power supply and I'm fine ...
    Thank you
    https://postimg.cc/gallery/hhPmPFk
  • nomoresonys
    • 12331
    • U.S.
    Re: Sony kd 65s8505c problem
    With tv unplugged press and hold power and volume down buttons on tv, keep holding while plugging in tv you can let go when you see green light on front or tv starts up, give it a try.
    • mermel
      • Nov 2016
      • 17
      not working to reset
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • retrorepair
        SONY KDL-40P3600 Picture Problem
        by retrorepair
        Hello gurus, hope you can assist me...
        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
        Thanks in advance.
        10-11-2024, 05:12 PM
      • guruji
        Sony mbx-266 problem
        by guruji
        Hello
        I this Sony mbx-266 it powers
        on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
        07-25-2025, 08:10 AM
      • YasaCh
        sony kd-49xf9005 4 red blinking problem
        by YasaCh
        Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
        05-05-2025, 08:40 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
