Magnavox 27MS5402/17 CRT - no picture, flashing green light
  • sudz28
    • Feb 2022
    I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
    My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more flashes, and another long flash. After that the pattern repeats. I have no service manual or anything to decode what these flashes may mean, and no experience with troubleshooting tv's or really electronics in general to begin with. Any chance someone here is at least passingly familiar enough with these to either day "Oh yeah, the entire thing is not worth savings, sorry for your loss!" or "Oh that is almost certainly just a bad capacitor or a broken solder joint - check <here> for an issue!"?
    Many thanks for any assistance!
  • R_J
    • Jun 2012
    • 9610
    Re: Magnavox 27MS5402/17 CRT - no picture, flashing green light
    What voltages have you checked so far? Did you download the service manual for this tv? if not start with that: https://www.manualslib.com/manual/69...s-A02u-Aa.html
    7 flash = Under-voltage protection
    3 flash = +8V error (missing/protection active by checking MPIF ASUP bit)
    Check the standby +11 volts, this might be low.
    • nomoresonys
      • 12307
      • U.S.
      If you can't fix it, check craigslist they give crt tvs away pretty much daily.
      • sudz28
        • Feb 2022
        Thank you, I had been trying to find something online that would tell me what the green flashes meant; I assumed they were a specific code that a service person would know, but I wasn't sure how to go about divining them.
        So on Sunday I had taken the back off thing to look for 'obvious' problems (not really sure what I was looking for, but figured if I saw something on fire that would be bad) and cleaned off circuitry as best I could with qtips and rubbing alcohol; it still wouldn't work, so I figured it was a bigger issue. Tonight I power it back on just to double-check the light sequences and what do you know but that it's working again! I have no clue how or why, it still wasn't working after my 'cleaning' I gave it on Sunday, but it seems to have come back to life. At least for now.
        To answer your specific question, I hadn't checked for any voltages yet because although I own a multimeter, I haven't used it for anything more than checking car and riding mower batteries and have no idea how I'd go about checking anything on this set. This was what I was hoping to get guidance on, but it seems that now I don't have to?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Sounds like a capacitor issue. Electronics that sit around can have problems when restarting.
          • sudz28
            • Feb 2022
            Based on this, I'm guessing then that going forward sometimes the set may turn on just fine and other times it may not? Or are you saying the fact that it sat around for a year could be why it had a hard time firing up initially, but now that it's working it should be good to go from now on? Hmmmm, maybe it's worth taking the back off again and doing what I can to check the capacitors better.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Electrolytic capacitors lose their insulating properties over time. And have to be reformed to work. Applying power to them reforms the insulation unless to much is lost. In which case they will short out and be permanently damaged. They may have only been leaky and caused a problem until they reformed their insulating properties. Capacitors are about the only component that has an operational lifetime.
              • MOSSEP
                Monitor Audio RSW12 - Green light, but no sound
                by MOSSEP
                Hi
                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                I have already tried replacing all of the...
                01-26-2025, 08:33 AM
              • MOSSEP
                Monitor Audio RSW12 - Green light but no audio
                by MOSSEP
                Hi
                01-26-2025, 08:18 AM
              • lcdcaps1
                820-2610-A Sys onewire help, no green light. Please help from the gurus
                by lcdcaps1
                Hi
                I have an 820-2610-A motherboard that has no green light.
                I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                The sys onewire circuit on this model and others is more involved
                I was hoping if anyone knows about this and how it works, can reply and let me know
                I know this is an old model but I am sure there are people who still works on these or knows about them
                I get 1.1v on the C7771 capacitor and will replace...
                11-06-2023, 01:28 PM
              • matthewmcconaughey
                I need help with my friend Sony GDM-FW900 24” CRT
                by matthewmcconaughey
                Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                1. It started with a bright and greenish picture upon starting a cold monitor.
                2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                05-16-2023, 03:15 PM
              • esqmooo
                HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                by esqmooo
                Hello everyone.
                This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                03-11-2025, 03:57 PM
