Sony KDL70W850
  • Elroy
    • Dec 2013
    • 6
    • Belize
    Sony KDL70W850
    Morning i have a Sony KDL70W850 that i am working on anyone have a service manual or schematic to please help me with
  • nomoresonys
    • 12331
    • U.S.
    Re: Sony KDL70W850
    What's wrong with it?
    • Elroy
      • Dec 2013
      • 6
      • Belize
      Re: Sony KDL70W850
      came in power up and then turn off error code 5 blinks. I disconnected the T-Con board and it stay on with backlight. Check T-Con not getting any voltage at fuse. Change main board and the LED on panel light green
      • nomoresonys
        • 12331
        • U.S.
        Re: Sony KDL70W850
        Usually always need to update/pair the new mainboard, sonys especially.
        • Elroy
          • Dec 2013
          • 6
          • Belize
          Re: Sony KDL70W850
          tried update as was mention but to no avail.
          • nomoresonys
            • 12331
            • U.S.
            Re: Sony KDL70W850
            With tv unplugged press and hold power and volume down buttons on tv, keep holding while plugging in tv you can let go when you see green light on front or tv starts up.
            • nomoresonys
              • 12331
              • U.S.
              Re: Sony KDL70W850
              Can try, with tv unplugged from power disconect one tcon ribbon cable at a time plug in tv check display, then do same on other side, to avoid problems always connect and disconnect cables with tv unplugged from power, report results.
              • nomoresonys
                • 12331
                • U.S.
                Re: Sony KDL70W850
                After that, maybe check the little caps on the panel driver board for shorts or very low ohms, there's other components on them that can go bad too, the caps are easy to check, probably expect over 100 ohms, if the panel is not easy to get at maybe try the tape cut-off method, been covered here many times, can put it in search above.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Re: Sony KDL70W850
                  So did you then get voltage at your t-con?
                  • nomoresonys
                    • 12331
                    • U.S.
                    Re: Sony KDL70W850
                    Wondering if maybe the tv didn't care for the usb drive, can you try another usb drive and follow the procedure on sony site very closely.
                    • charlie555
                      • Feb 2018
                      • 76
                      • usa
                      Re: Sony KDL70W850
                      Disconnect one of the ribbon cables from panel board to tcon board then check for image then the other side.
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
