Help with Sony KDL-37S5500 TV Display issue please
  • WiseMoves
    • Jan 2022
    • 15
    Hello everyone thank you in advance for taking your time to help me solve this issue.
    I have a screen that is showing a negative look or low pixel resolution. I have attached a photo here of the current issue.
    I did some research and everyone pointed to a small chip on one PCB that's was the cause on the T-CON LVDS BOARD. So I managed to locate another board same version. I swapped out the board only not to have solved the problem to my disappointment.
    So here I am asking if anyone has some advice in regards to this, is there another main cause.
    All the cables where cleaned and re-seated.
    I've also attached the board that I changed out.
    Thank you all in advance for any help.
    • 12254
    • U.S.
    Re: Help with Sony KDL-37S5500 TV Display issue please
    Try a factory reset, no joy, try a firmware update, two pretty easy things to try. Can you take a better close up picture of the tcon? can't see any detail in that one.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Any other work done to it? Maybe wrong format.
        • 12254
        • U.S.
        Good point Dskall, might need to go in and change the format.
        • WiseMoves
          • Jan 2022
          • 15
          Hi all
          To nomoresonys : Please see attached files of T-con board close up.
          How do you propose to do factory reset, or a firmware update please.
          To dskall :
          No other work to my knowledge.
          Maybe wrong format ( in which sense please)
          Are you referring to bit i.e. 8 to 16 or 32 bit I could not see any setting that referred to this.
          Thank you for assistants regarding this.
          • Diah
            • Feb 2013
            • 6431
            write over here the main chip label of the t-con not clear at photo.. some certain chips known by Gama fault.
            • lotas
              • Jan 2016
              • 4718
              • Russia
              He has the RM5101 (AS15) gamma.
              • R_J
                • 9583
                Check the VG voltages and right them down. The test points are VG1 ~ VG21
                VG1-- __
                VG2-- __
                VG21-- __
                The voltage should be fairly liner from VG1 to VG21
                  • 12254
                  • U.S.
                  If those things check out, for the factory reset you can try this: menu options: Select Device Preferences → Reset → Factory data reset → Erase everything → Yes, might work your model may be different, would check the chip and all on tcon as suggested first.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    He did say he replaced boards, but possible they both had same problem.
                      • 12254
                      • U.S.
                      It is a sony, every time you sneeze you should update a sony, lol.
                      • WiseMoves
                        • Jan 2022
                        • 15
                        Hi everyone
                        Diah : I have attached better photo's in macro so you can read the chip ID better.
                        Lotas : Please see attached, does this chip have a gamma issue, and which chipset should I have to avoid this issue.
                        dskall : Yes I did think that myself as I can't confirm the other board that I purchased was good other than what the seller stated. If that's not correct then we are looking at a different problem but everyone leads to this card, to be the source of the issue.
                        R_J : Where are these test points VG1 ~ VG21 located you are referring to please.
                        Nomoresonys : I did reset the software when I went into the service side looking for a pixel bit size nothing so I reset and still the same no change.
                        How do I update the Sony having never done one before.
                        Thank you kindly for your help.
                        • Diah
                          • Feb 2013
                          • 6431
                          yours photo .. yes this is the fault gama chip
                          take look on this video
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            They are scattered but VG1 > vg19 are test points. I would access service menu and make sure you are on right lvds format.
                            • WiseMoves
                              • Jan 2022
                              • 15
                              Hi everyone
                              Diah: Do you know the best replacement chip that does not have gamma issues please.
                              • WiseMoves
                                • Jan 2022
                                • 15
                                Just found this:
                                https://www.youtube.com/watch?v=bAQrDV_AOg0
                                Same board he replace's the IC with AS15 G at 8.21 in the video and solves the issue.
                                Please correct me if I am wrong but the replacement IC's are
                                AS15F, AS15 G, AS15 U, AS15 H, AS15 HF, AS15 AF.
                                This replaces the:
                                RW5101
                                A0W936.1
                                0930A5TG
                                Advice please.
                                • Diah
                                  • Feb 2013
                                  • 6431
                                  Originally posted by WiseMoves
                                  Hi everyone
                                  No guarantee on this chip.. could remain good over 15 years and more or after one months cut the gamma so replace it same with out thinking on good or better,
                                  • R_J
                                    • 9583
                                    Just found this:
                                    This replaces the:
                                    RW5101
                                    A0W936.1
                                    0930A5TG
                                    Advice please.
                                    It looks like the RM5101 replaces the AS15-xx
                                    • Diah
                                      • Feb 2013
                                      • 6431
                                      RM is Original Taiwanese .. AS Chinese ( Main Land ) COPY
                                      • cheeky2
                                        • Dec 2012
                                        • 337
                                        Indeed the AS15X replace this one. If you find a RM5101 they are far more expensive than the AS15x range. The RM5101 are far more reliable than the AS15X ics though I have found.
