LG 55EG960V won’t turn on.
  • chopper00
    • Jan 2012
    • 60
    Got above OLED set, won't turn on in standard power mode, get this when trying to use power only mode from service remote. Any ideas?
  • Diah
    • Feb 2013
    • 6611
    Re: LG 55EG960V won't turn on.
    this cant be and it show this with power only..
    exit the power only mode and power it normal. look at the Optical sound port lit red or not,
    • chopper00
      • Jan 2012
      • 60
      This only happens for about 2 seconds then a click and switches off. Optical port lights for the same time. LG logo just flashes with standard remote.
      • Diah
        • Feb 2013
        • 6611
        so after this 2 seconds it goes to standby correct ? if yes press with original remote the power again and tell what you have
        • chopper00
          • Jan 2012
          • 60
          It will do the same for a couple of times and then go back to flashing logo. If I use power only it will start every time but only for 2 seconds approx.
          • Diah
            • Feb 2013
            • 6611
            don't use power only.. just power it with original RC. unplug the cable of 24v between the power boards and the t_CON driver boards then turn on.. always use the remark of powering on the optical ports.
            • chopper00
              • Jan 2012
              • 60
              Thanks, will check tomorrow as I’m not with the set now.
              • chopper00
                • Jan 2012
                • 60
                24v cable removed from t-con board, power on with standard remote, nothing, lg logo flashes, power on with service remote “power only” power board relay clicks, nothing on display, optical port lights for one second then clicks off. Standard remote then does the same for two try’s. Standard remote does nothing until “power only” command is sent from service remote.
                • chopper00
                  • Jan 2012
                  • 60
                  ***UPDATE*** I have replaced the mainboard and the tv is now powered on and working although I have a single line down the screen. Does this mean the screen is faulty?
                    • 12322
                    • U.S.
                    Maybe clean and reseat all the ribbon cable contacts of the tcon, carefully, can use isopropyl alcohol and a qtip, some use a pencil eraser, just reseating may do it, sometimes a slight misalignment can cause problems.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      have a search through the forum there is another thread with this centre vertical line issue
                      • Diah
                        • Feb 2013
                        • 6611
                        i just wondering from where you bring the photos LOL
                        common... we still in Jan not April
                        • chopper00
                          • Jan 2012
                          • 60
                          Thanks, I will give that a try 👍🏻
                          • chopper00
                            • Jan 2012
                            • 60
                            Thanks I'll have a search 👍🏻
                            • chopper00
                              • Jan 2012
                              • 60
                              The pictures were taken at the time of the post 😂
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • masoksian
                                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                by masoksian
                                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                The system does not turn on, there is no post.
                                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                The problem continues in the same way.
                                I tried to turn on the Fn key, nothing came to the screen....
                                02-15-2025, 12:08 PM
                              • maxim2511
                                LG 55EC930V OLED - swich on swich of no screen
                                by maxim2511
                                My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                Then I get an idea to take it apart and clean boards from dust.
                                In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                05-14-2021, 02:21 AM
                                09-06-2024, 05:59 AM
                              • Journey11
                                Samsung TV won't turn on ... keeps cycling the power relay on & off
                                by Journey11
                                Hi All,
                                First time posting here ... my name is Kevin but my friends call me Journey.
                                I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                07-04-2024, 02:44 PM
