Grundig 55 GUB 8860 - bad T-Con or bad panel?
  • Diah
    • Feb 2013
    • 6439
    Re: Grundig 55 GUB 8860 - bad T-Con or bad panel?
    the way you did GPU use the same Temp ca 250 !! and time
    • Ierwin
      • Jul 2017
      • 103
      I don't remember what Temperature I used back then, it's been 15 years.
      Some sites suggested starting at 100°c and working up from there so that's what I'll do
      As far as I remember you can't really reach a temperature where the solder completely melts without proper tools, only enough for it to get soft and possibly regain connection.
      Will report my results
      • Ierwin
        • Jul 2017
        • 103
        Oh if you or anyone else has a chance to get their hands on the correct panel.bin I would still be very interested. As far as I understand I could use a replacement Mainboard from a TV with a different panel then so it would be way easier to find a used part
        • Diah
          • Feb 2013
          • 6439
          can you measure the reading of the small parts connected to pin 44 ? lvds most disconnected during measurements
          • Ierwin
            • Jul 2017
            • 103
            Do you mean this tiny C? With all cables disconnected I'm reading 0V.
            Might be short but didn't check for other parts in parallel yet
            • Diah
              • Feb 2013
              • 6439
              it is L not C so it read continues ?
              • Ierwin
                • Jul 2017
                • 103
                Yes,if it is L it's okay
                • Ierwin
                  • Jul 2017
                  • 103
                  I went up until 200°C with the oven and left the board in for 10 minutes.
                  No change at all and I fear if I go higher the plastic ob the connectors could melt.
                  • Diah
                    • Feb 2013
                    • 6439
                    200°not enough..in the factory when they apply the soldering pasta first and then the components , it move to the oven which first step 200 then to 310 then back to 150 to the cooling station. t´he worry you have about sockets you can apply kitchen aluminum paper to shape it like cups to cover them. put don't let the paper touch them. this is the packing which i use. beside other method to use Korean in room infrared grill if i want to go only on specification area / chips
                    • Ierwin
                      • Jul 2017
                      • 103
                      Its time to give up unless I find a really cheap mainboard I think.
                      Thank you for the help, I have now taken it to the point where the mainboard is definetly toast.
                      I thought it would be smarter to heat up the main chip with a heatgun on low blow setting, while I monitored the chips temperature with an infrared thermometer. Slowly heated it up until the surface reached 250 very briefly, then went down to 190 then let it cool.
                      That killed it.
                      Now when I plug the set in, the PSU makes a humming noise and the blue led is no longer blinking
                      • Diah
                        • Feb 2013
                        • 6439
                        That killed it.
                        what ...??we didn't mentioned at all to use hot air gun.. however if some one read this thread in case using normal hot air gun we should cover the chips and all components around with type to avoid one of them move or flying out. and this what happen now.
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • netgearnetgear
                          TCL 43S423 TCON OR PANEL FAULTY???
                          by netgearnetgear
                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                          08-20-2025, 06:04 PM
                        • mmartell
                          General Questions on the Relationship Between Mainboard, TCON and Panel
                          by mmartell
                          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                          01-06-2024, 01:32 PM
                        • Helikvar
                          Hisense 58A6KV
                          by Helikvar
                          No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                          . Backlights also light up when tv is powered on.
                          Removing panel ribbon cable from left side screen still dark.
                          Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                          . Tcon gets 12 volt
                          . Tried taping...
                          02-21-2025, 03:52 PM
