Grundig 55 GUB 8860 - bad T-Con or bad panel?
  • Ierwin
    • Jul 2017
    • 103
    Re: Grundig 55 GUB 8860 - bad T-Con or bad panel?
    I have an update but at the moment it is not a good one:
    I did some trial and error with various USB sticks and SW versions, pressing buttons, pluggin in, plugging out, never got anything on the screen.
    I found out that pressing the "+" Button while plugging in with the USB stick in USB1 caused the TV to do "something". It briefly turned on the backlight, like it was starting and then shut off (all within 5 Seconds or so).
    I figured maybe (I know you doubted that, but MAYBE) the T-con IS broken. So I unplugged the left ribbon again and performed the update procedure.
    For a very short moment, not more than a second the large white letters and the progress bar of the software update screen were visible on one half of the screen.
    It was really just a short flash, I only know it was the update screen, because I recognized it from some of the PDF guides.
    I powered the set up once more with the ribbon disconnected and got to the menu again on half the screen. I am not 100% sure but I think the menu looked different from before. It had colorful Icons of Netflix or YouTube that I do not recall heaving seen during my cooling spray tests.
    I connected the ribbon again and tried to install the old firmware.
    And ever since then it has gotten worse.
    I am not getting any picture at all now. Not even with the ribbon disconnected.
    When I start the set and push the menu button on the remote the backlight gets brighter but nothng is visible on the screen
    • Diah
      • Feb 2013
      • 6343
      do it the way you worked on the last firmware.. when you have saw what you saw before go to access the panel buffer boards... show here clear photo on both side
      • Diah
        • Feb 2013
        • 6343
        yours chassis servive manual..read page 112
        • Ierwin
          • Jul 2017
          • 103
          So since I have 12V on the TCon Fuse the next step would be to check "L402" and "Tcon_On". I dont know where those are
          • Ierwin
            • Jul 2017
            • 103
            It also says in the manual to update the panel.bin and there ist a description how this file has to be placed inside a folder on the USB stick.
            I do not have a panel file and all the directories in BIN_FILES are empty
            • Diah
              • Feb 2013
              • 6343
              Arçelik_Beko_Grundig_Released_Panel_Files
              • Ierwin
                • Jul 2017
                • 103
                thank you so much!
                But how do I find the panel type? I was hoping it was on one of the bar codes but havent found a mathcing number yet
                • Ierwin
                  • Jul 2017
                  • 103
                  according to the small sticker on the back I think I have a 55C46 Panel. At least that is the number that comes closest to the filenames in the zip.
                  But no file for that in the zip
                  • Ierwin
                    • Jul 2017
                    • 103
                    In the Service Manual is says:
                    Updating panel file
                    Inside of the BIN_FILES folder must appear
                    as below. Select the appropriate panel file
                    from O2_PANELLER.rar in the WEB folder.
                    Copy the file in the panel file folder and
                    paste it into the Keys folder.
                    So if you actually have access to that "WEB folder" that would be the file to look for
                    • Diah
                      • Feb 2013
                      • 6343
                      both the firmware you downgrade and update didnt have panel.bin at panel & key folders so it mean the process will write the firmware with out touching the sector of panel data on eeprom. howver when it flashed the firmware it will reset the eeprom so the panel data will remain.
                      did you try to press the menu ? did some things apear on screen... did the backlight lit more high when you press menu ???
                      • Diah
                        • Feb 2013
                        • 6343
                        the panel ID you can find ir at other small sticker at the middle top of the chassis where written on it GRUNDIG
                        • Ierwin
                          • Jul 2017
                          • 103
                          pressing menu the backlight goes brighhter but nothing apears on the screen.
                          I have never had a panel.bin on my USB stick, so it should never have overwritten. But because it stopped working after one of these flashing attempts I think the panel setting might have been deleted.
                          I found the ssticker on the chasis (fun fact: couldnt find it before because my multimeter was standing on it ).
                          But the number is the same as the small sticker on the back: 55C46P
                          • Diah
                            • Feb 2013
                            • 6343
                            okay,,, you need to inspect the LVDS cable and the 2 ribbon cable under good loop. the material they used on this TV are the cheapest one with bad quality easy the contact pin after 1-2 time take them out from the socket will brocken
                            • Ierwin
                              • Jul 2017
                              • 103
                              Okay so I measured all the ribbons with a continiuty tester (beeping).
                              I slowly draged the probes over the contacts of the connectors on each side.
                              I admit I did not take the time to probe each of the tiny contacts perfectly individually so if lines are shorted I wouldn't know. But at least I did not find any broken lines
                              • Diah
                                • Feb 2013
                                • 6343
                                Okay. now every things in place and follow the S.M after turn on and you press menu ( BL go brightness) measure voltage on pin 44 & 51 if you have missing V on 44 check the yellow parts.
                                • Ierwin
                                  • Jul 2017
                                  • 103
                                  I found that section of the SM earlier and checked. I'm not at home right now and don't remember the voltages but both were equal.12V I think. Definitely not 0
                                  • Diah
                                    • Feb 2013
                                    • 6343
                                    if both pins 44 & 51 have V. then my early post #8 are in place... you have drooped signal feed with main IC on main boards.
                                    • Ierwin
                                      • Jul 2017
                                      • 103
                                      So a loose BGA maybe? That's probably not repairable. But it would be possible that the connection was bad/failing and when I applied cooling spray the temperature stress on the soldering joints made it worse.
                                      So nothing else to do but get a replacement Mainboard?
                                      • Diah
                                        • Feb 2013
                                        • 6343
                                        well. before i go to buy replacement MB the stress you mentioned could be, in this case i encourage you to packing the MB. in the oven with out air flew after you remove from the down side i think there are rubber legs
                                        • Ierwin
                                          • Jul 2017
                                          • 103
                                          What temperature do you suggest?
                                          I once got a GPU back to life with this technique so I know it might be worth a try
                                          • mmartell
                                            General Questions on the Relationship Between Mainboard, TCON and Panel
                                            by mmartell
                                            My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                            I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                            And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                            01-06-2024, 01:32 PM
                                          • Helikvar
                                            Hisense 58A6KV
                                            by Helikvar
                                            No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                                            . Backlights also light up when tv is powered on.
                                            Removing panel ribbon cable from left side screen still dark.
                                            Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                                            . Tcon gets 12 volt
                                            . Tried taping...
                                            02-21-2025, 03:52 PM
                                          • Lee M.
                                            Amazon Fire TV Omni K24NE5 tcon or panel bad?
                                            by Lee M.
                                            TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
                                            05-12-2023, 05:47 PM
                                          • ashyt16
                                            Toshiba TV bad panel half screen dark - pull tabs or not?
                                            by ashyt16
                                            Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
                                            The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
                                            Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
                                            I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
                                            10-26-2020, 05:47 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
