Grundig 55 GUB 8860 - bad T-Con or bad panel?
  • Ierwin
    • Jul 2017
    • 103
    so another broken LCD found its way on my workbench and I take the opportunity to dig into analyzis and learn something in the progress.
    Unfortunately I could not find a service manal for this device, but at the moment I am not even sure that schematics would be much help.
    When I power up the set the screen stays dark. I can see that the backlight lights up but there is no picture on the screen.
    I suspect that this is either an issue with the t-con or with the panel itself.
    To rule out one or the other I detached the cables of leading from the t-con to the panel one by one. With the left cable removed I get half a picture for a short time, before it turns into just some gray lines.
    I attached pictures that show the individual stages of startup.
    With the right cable removed and only the left connected one side stays white, the other black.
    I read that when you get half a picture with one cable removed it is likely that the disconnected side of the panel is bad. However I am not sure if this is the case here because the other side does only hold the picture for a couple of seconds.
    Is it worth hunting down a replacement T-con?
    Anything else I could test to narrow down the root cause?
    Best regards
    Kolja
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Grundig 55 GUB 8860 - bad T-Con or bad panel?
    What does other side do?
    • Diah
      • Feb 2013
      • 6399
      GUB 8860 as much i remember it had T-CON interrogated at panel, can you show here the back side..
      • Ierwin
        • Jul 2017
        • 103
        When I connect the other cable to the tcon the connected half of the panel stays black while the disconnected side goes white.
        • dskall
          • Oct 2016
          • 2905
          • usa
          In this case I might suspect the side with the picture is dragging down voltages.
          • Ierwin
            • Jul 2017
            • 103
            so its a panel issue?
            Anything worth checking or is thin generally an unrepairable thing?
            • Ierwin
              • Jul 2017
              • 103
              So I did some reading and came across other threads of people having the same or quite similar issues.
              One suggestion is always to check the capacitors on the driver board of the faulty side for shorts, which I did but could not find any.
              Another apparently common fix is to tape certain parts of the t-con connector. One video I found specifically mentioned blocking the CLOCK signals.
              I attached a picture of the T-Con.
              The left side of the board where the ribbon cable is disconnected in the picture is the one that corresponds to the faulty side. Powering up with the cable disconnected like in the attached picture gives me half the image as shown before.
              Unfortunately only the right connector has pins that are clearly marked CLK1 to CLK10, so I have no Idea where to start taping.
              I randomly taped pins on the left cable but could never get anything but either the completely black screen (same as with fully connected cable) or the half white, half working (as it is when the left cable is disconnected)
              could the fact that even with the left cable disconnected the half picture does not stay stable but instead fades to grey after a few seconds indicate that the T-Con ist faulty too? Like maybe the faulty panel has killed the T-con, therefore taping does not help?
              • Diah
                • Feb 2013
                • 6399
                first my memory it seem going bad, yours tv with external t-CON so---
                yours panel are fine don't play with it at all. either your T-CON, you have drooped signal feed with main IC on main boards. reason could be BGA or caps on MB. use cool spray or heat MB see which part will make the tv displaying good picture in case no BGA at main IC
                BTW- if you have at the panel boards at the middle U ribbon try disconnect one and see the result.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  I would be checking t-con voltages with ribbons unhooked and connected. You could also check and see if your lvds signals are still there.
                  • Ierwin
                    • Jul 2017
                    • 103
                    Could you explain which Testpoints I should be checking?
                    I did some searching yesterday and found the t-con fairly cheap online. Would be definetly worth to repair the set of it turns out that only the tcon is bad.
                    • Ierwin
                      • Jul 2017
                      • 103
                      Okay so I just gave the cooling spray a try. I disconnected the left ribbon cable so I got a good picture on the right side. As said before this fades to gray after a few seconds.
                      By cooling the MB I was able to get the picture to come back.
                      This seems to work best right after the TV is plugged in, so I found it dificult to tell what area of the MB reacts to the cooling.
                      I attached a picture of the MB and the area that gets the picture back when cooled. Spraying directly on IC300 didnt help, it more in the area left of it.
                      Since I have the black screen when both cables are connected and also the MB changing with temp, could it be that both T-con and MB are broken? That would be really bad luck.
                      • Diah
                        • Feb 2013
                        • 6399
                        first of all, clean yours MB from all dust. also take it out and clean it from the back side-
                        second don't disconnect any cable of ribbon. keep the panel connect to t-con as it should.
                        then on main boards just unplug the speaker and the wifi module if exist..
                        turn on and while its on change source to any of HDMI and feed it with signal ( the purpose of this to check if the Firmware cause this trouble and remove more loud from the MB ) show me the result. and if you can record the issue to see how the fade its start.
                        • Ierwin
                          • Jul 2017
                          • 103
                          When both Cables are connected to the T-con the screen just stays black with the backlight lit. The oly way I can get any picture at all is disconnecting left ribbon
                            • 12206
                            • U.S.
                            Could be panel, I would try the "tape cutoff" method, can put it in the search to see threads/posts.
                            • Diah
                              • Feb 2013
                              • 6399
                              doesn't matter if the screen stay black.. you need to find the issue so let it. feed it with HDMI it will switch automatically to the port so u can hear the sound.
                              did you check on the socket either PCB or MB the 12V. if it dropping down. if its okay in the range..
                              then you need to capture the boot log with TeraTerm so we will know whats going on
                              • Ierwin
                                • Jul 2017
                                • 103
                                I didn't check any voltages at all yet, but will defined do.
                                Never heard about using s terminal program with a TV.
                                Im working in IT (although a different field) so that's a part of TV repair I am really curious to learn about.
                                Will do some research later and get back with more questions or new knowledge
                                • Ierwin
                                  • Jul 2017
                                  • 103
                                  Uhm...maybe I should clarify that the FireTV logo that can be seen on the photos does NOT come from the TV but from a TV stick I used as HDMI Input.
                                  So just in case this may have caused confusion. I didn't realize it might have caused a misunderstanding until now.
                                  So the TV seems to boot up perfectly fine, reacts to the remote control and so on.
                                  Earlier when I did the tests with cooling spray I didn't even use the TV stick and instead opened the menu to have something on the display to test with.
                                  • Diah
                                    • Feb 2013
                                    • 6399
                                    as i wrote before i don't think its fault at panel or t-con. Grundig/Beko/Arcelik Firmware are rubbish easy glitch happen by panel.bin specially if some one log in service menu and try to change values from customers to factory.
                                    so far seem you are far from using service port on TV to tracing fault. so the easy way to write complete firmware again so the set will deal if there part of panel firmware or pfeg. etc
                                    in case yours MB chassis O2 as i think. you need to double check.. download the last actual firmware for chassis O2.
                                    you need USB stick formatted with FAT32 MBR mode, put the file name Target_G10 on the directory of the USB, insert the stick at any USB port V2 not 3 (blue color ) on the back of the TV press the joystick and hold it press then plug it on wall. release after you can see updating screen.
                                    you can also downgrade the firmware.. go here and look after your chSSIS OLD VERSION
                                    • Ierwin
                                      • Jul 2017
                                      • 103
                                      Okay, that sounds like its worth a try.
                                      Also the links you posted really make it seem like the mos common issue with these sets are software related.
                                      You are right about the chassis btw, it is an O2 according to the sticker on the back.
                                      First attempt at flashing did not work but there is still plenty of room for error so i might have more reading to do in the pages you linked. For example my board has two USB slots, one labeled "USB1" on the side, the other on the bottom is not labeled. Im also not sure wich button to press and might even have to try a couple USB sticks.
                                      You say to press the "Joystick" and so do some of the guides I found. My TV only has 4 regular buttons on the MB labeled "+", "V/P", "-" and the power/Standby sign. Unfortunately the PDF I found on your link named "NT O2 O3 O4 O5 Anleitung.PDF" only describes how to update by usb in the menu.
                                      Anyway, this gives me a direction to work on
                                      • Diah
                                        • Feb 2013
                                        • 6399
                                        then press P+ keep hold while you plug in wall.
                                        you can use this page to inter the bar code No then download old and new version from the mother brand of this TV
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • mmartell
                                          General Questions on the Relationship Between Mainboard, TCON and Panel
                                          by mmartell
                                          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                          01-06-2024, 01:32 PM
                                        • Helikvar
                                          Hisense 58A6KV
                                          by Helikvar
                                          No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                                          . Backlights also light up when tv is powered on.
                                          Removing panel ribbon cable from left side screen still dark.
                                          Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                                          . Tcon gets 12 volt
                                          . Tried taping...
                                          02-21-2025, 03:52 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
