philips 32pfl5507k/12
  • StromarMiki
    • Oct 2021
    • 25
    • Slovenija
    Hi, for philips i need service manual.
    I have problem with power supplay DPS-98EP A
    I change fuse and TK13A65U. But not have voltage 12V only 3.3V.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: philips 32pfl5507k/12
    Have a look at
    https://english.electronica-pt.com/e...=32PFL5507K/12
    • StromarMiki
      • Oct 2021
      • 25
      • Slovenija
      I already found it. i have ERROR CODES - LED BLINKING CODES.
      4s pause and 3 fast flashing led blinking. I can't find this error.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Why do you need error codes if you know the problem?
        • StromarMiki
          • Oct 2021
          • 25
          • Slovenija
          when connected to the power supply, red led blinking. (4s pause and 3 fast flashing led)
          Voltage is only 3.3V.
          • R_J
            • 9532
            Where is TK13A65U in the circuit? is it in the standby, pfc or main circuit?
            Usually when a mosfet like this shorts it opens the source resistor and can damage the drive ic as well.
            • StromarMiki
              • Oct 2021
              • 25
              • Slovenija
              i can't find it in the service manual.
              • R_J
                • 9532
                The service manual does not have the dps-98ep schematic. That does look like the main mosfet that drives the main transformer. There is a resistor R611 0.24Ω (mosfet source) located beside that heatsink, check that it is not open, I expect that it is open. If R611 is open, check R610 as well, it connects the mosfet source to ic601'a CS pin.
                • StromarMiki
                  • Oct 2021
                  • 25
                  • Slovenija
                  I marked it wrong, TK13A65U is located on the second aluminum plate.
                  • R_J
                    • 9532
                    What is its board location number? that looks to be a Diode (D120)?
                    Do you have any voltage across C700A or C120A? (I'm not sure of the numbers).
                    If it was indeed a mosfet I suspect it is used to switch a voltage
                    • StromarMiki
                      • Oct 2021
                      • 25
                      • Slovenija
                      No voltage on c120 and mosfet.
                      The problem is on the primary of the transformer
                      IC 601 may not work. How can I check the operation of the transformer.
                      • R_J
                        • 9532
                        Check R611 0.24 resistor and see if it is open What is the number on Q601 AND IC601?
                        • StromarMiki
                          • Oct 2021
                          • 25
                          • Slovenija
                          R611 is good-closed, Q601 is good, ic601 2QS02G
                          • R_J
                            • 9532
                            Do you have vcc voltage (20v) on pin7 of ic601? be careful not to short the ic pins. There is a resistor connected to pin7, check the voltage there instead of on the ic.
                            I suspect there is no vcc and the supply for the vcc comes from the standby circuit.
                            I am starting to think there is no power on signal from the main board. I suspect PC903 is the optocoupler that turns on the power supply
                            CN4 pin 2 standby should be the power supply on. With CN4 disconnected from the main board, connect pin 1 (3.3v) to pin 2 (standby) and see if you get your 12 volts.
                            • StromarMiki
                              • Oct 2021
                              • 25
                              • Slovenija
                              ic601 pin7 no VCC
                              CN4 PIN5 no VCC 12V
                              Power in pin2 is 3V mainboard is work.
                              • R_J
                                • 9532
                                ic601 pin7 no VCC
                                CN4 PIN5 no VCC 12V
                                Does ic601 pin 7 connect to J17 and then to J9?
                                How do you know the main board is working and sending the power ON signal?
                                • StromarMiki
                                  • Oct 2021
                                  • 25
                                  • Slovenija
                                  when connect CN4 on main board in pin 2 have 3v vcc.
                                  and dont have 12v. I thinks is problem in power board.
                                  • R_J
                                    • 9532
                                    Does the voltage on pin2 change when you press the power button?
                                    CN4 pin 1 is the standby 3.3 volts that supplies the main board, CN4 pin 2 turns the power supply on and off.
                                    • StromarMiki
                                      • Oct 2021
                                      • 25
                                      • Slovenija
                                      When I connect the power cable to 220v only red led blinking.
                                      The main board works but reports an error.
                                      Voltage failure is possible.
                                      • R_J
                                        • 9532
                                        Here it is listed under layer 1
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • mecha1166
                                          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                          by mecha1166
                                          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                          03-28-2024, 08:31 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
