Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
  • freccia
    • Mar 2012
    • 26
    • Malta
    I have a Finlux/Vestel Led Tv with the following fault and cannot reason from where the fault is. Fault is:
    Sound ok, Backlight ok, Picture nothing but colour vertical lines. power supply vestel 17 IPS 71, main board 17MB82S
    Checked 12V on tcon on fuse ok.
    Checked 12v and 24v on power supply ok.
    Volume works. removed l left ribbon cable no picture white on half, and same with right one.
    Any idea from where I can start please?
    Any help appreciated please.
  • freccia
    • Mar 2012
    • 26
    • Malta
    Re: Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
    About the photo take, please note that that is the flash not a broken display. Also volume works as sound not on scrren display.
    24v measured on a capacitor on the secondary of the power supply.
    Photo is taken with both tcon ribbon cables connected.
    Also please find a photo of all the boards on this TV.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Doubt if this is your problem but need to check connector between power and main board for cracked solder joints. Then you need to take some voltage checks on t-con. Lower right corner for starts.
      • freccia
        • Mar 2012
        • 26
        • Malta
        Hi. thanks for your reply. Willcheck the solder joints between the main board and power supply. Will also measure the voltages at the test points on the right and come back with the readings.
        thanks
        • freccia
          • Mar 2012
          • 26
          • Malta
          Ok. Here are the voltages from the t-con right test points:
          VCOM 6.4V
          VCOMR_FB 6.4V
          VST -4.8V
          VGL_1 -4.8V
          VGH_EVEN 27.5V
          VGH_ODD 27.5V
          CLK1-CLK6 ALL 5.6V
          Do you see anthing wrong or abnormal in these voltages please?
          • freccia
            • Mar 2012
            • 26
            • Malta
            Measured more voltages on Tcon
            VCC 4.3V
            VGL -4.8V
            VGH 27.6V
            VCOML_FB 6.4V
            VA1 12V
            HVDD 8.3V
            VIN 12V
            VDD 16.7V
            Are these normal please?
            Last edited by freccia; 01-09-2022, 11:55 PM. Reason: forgot the negative sign on vgl
            • freccia
              • Mar 2012
              • 26
              • Malta
              I am stuck on this. Any help would be greatly appreciated please.
              • Diah
                • Feb 2013
                • 6367
                yours photo.. if you press menu or change source signal did you see some effect on those lines and color ?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  VCC 4.3V
                  VGL -4.8V
                  VGH 27.6V
                  VCOML_FB 6.4V
                  VA1 12V
                  HVDD 8.3V
                  VIN 12V
                  VDD 16.7V
                  These look OK.
                  • freccia
                    • Mar 2012
                    • 26
                    • Malta
                    If I connect a dvd player on scart, I can hear the sound, but picture remains the same, no menus or volume is shown on screen. Volume loudness works though, just not showing on the screen.
                    • freccia
                      • Mar 2012
                      • 26
                      • Malta
                      VCOM 6.4V
                      VCOMR_FB 6.4V
                      VST -4.8V
                      VGL_1 -4.8V
                      VGH_EVEN 27.5V
                      VGH_ODD 27.5V
                      CLK1-CLK6 ALL 5.6V
                      @DSKALL, do these other readings seem right to you?
                      Do you think that t-con is good?
                      I have no other boards to test with.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        I would say they are all OK. Try partially removing cable to t-con and moving it around to see if you get any picture. You may have bad cable or connection between main and t-con.
                        • freccia
                          • Mar 2012
                          • 26
                          • Malta
                          I tried to loosen it, I cleaned the contacts, but nothing,no change, picture never shows but remains as in sample previously attached. I will try to purchase a ribbon tcon cable and see what happens.
                            • 12184
                            • U.S.
                            One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
                            • freccia
                              • Mar 2012
                              • 26
                              • Malta
                              Thanks for your message. I have checked for dry joints on the power supply. I have ordered the ffc cable. It will take a while to arrive. Will replace it and let you know if it is from that cable. All voltages look ok, at least from my previous posts, it may also be the tcon but voltages look ok in the exit side, maybe it has an issue when connecting to the main board, no osd though. Will let you know when the part arrives, seller posted it today, THanks
                                • 12184
                                • U.S.
                                I would prolly throw another tcon at it if they don't cost too much.
                                • freccia
                                  • Mar 2012
                                  • 26
                                  • Malta
                                  I have changed the ffc tcon cable, saw the picture when i moved the cable but when i locked it in the same display with lines came up. Guess it is time to replace the tcon as well now.
                                    • 12184
                                    • U.S.
                                    That is a little strange, maybe try resetting those cables, might be just a slight bit misaligned, did you try resetting both the cable going to and leading out from tcon and the ones from tcon to panel driver board, can clean the contacts gently with isopropyl alcohol, some use a pencil eraser.
                                    • freccia
                                      • Mar 2012
                                      • 26
                                      • Malta
                                      That is a little strange, maybe try resetting those cables, might be just a slight bit misaligned.
                                      moved it slightly outwards of the lock position, the picture came full but went after a few seconds, so i think that it is either the socket has something or electronically something is happening. new ffc cable installed and same syptoms. Did clean them with alcohol, the ffc cable socket, but in vane. also disconnected the 2 tcon ribbon cables going to the panel, but same picture with lines appear. I am thinking that maybe tcon is somehow resetting or removing a short when the cable is slightly loose. must be the tcon i guess. but it will take me 2months for it to arrive.
                                        • 12184
                                        • U.S.
                                        Check the solder joints on the sockets.
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
