32" Trinitron loose wire
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    So I picked up a 32" Sony KV-32TS36 for free and the first thing I did after ensuring it worked (I was given it with a note saying it ran with a light tint of yellow) was take the back off and dust it out. Compared to my older 27" Sony, in this one all the boards are modular and could be removed which made dusting a lot easier.
    The problem is now that it is all back together I find myself with one spare cable. Two wires, white and gray, almost a foot long and the same connector on both ends. I never stopped to see where everything plugs in as I assumed all the connectors were different sizes. The only place I can find where there is a connector with nothing plugged into it is on the tuner board (both pins are ground) and on the main logic board (one pin is ground, the other is not and is marked "VIDEO PAL"). I'm not going to just plug it in and see what happens as the last thing I want to do is blow the boards. Any ideas or is it just a spare cable with no use?
    Also, is there any way to remove or reduce the tint? The guns are almost 20 years old so I'm sure a bit more voltage might help.
    Find Nedry!
    Check the Vending machines!!
  • Wizard
    • Mar 2008
    • 2296
    Re: 32" Trinitron loose wire
    This what you get for assuming.
    Anyway, tint, have you checked customer's menu that tint control is centered?
    20 years old TV will have automatic kine adjustment. It does it is denoted as "IK" pin on the CRT board. Do you have original remote for it. You need it for service menu.
    Linky:
    service manual
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      Unfortunately I do not have the original remote but I do still have a crapload of Sony remotes so I'm sure at least one of them will work.
      I'll lookover the service manual and see if I can get any more help there regarding the wiring and color adjustment as my tint has already been centered.
      Find Nedry!
      • Wizard
        • Mar 2008
        • 2296
        Service manual has the details and any remote that has same name of buttons should work on these sony remotes.
        Cheers, Wizard
        • pentium
          • Mar 2006
          • 2778
          Great. Not one but all four connectors (like I said, I got two sets of matching cables and four connectors with an idea where at least one of the cables go) are not listed in the service manual.
          This is one of these moments I wish I had a picture to refer to.
          FYI: The two mystery connectors are CN165 on the A board and I think CN168 on the M board. The other two were CN148 on the UA board and CN164 on the A board but they are both nothing but grounds so nothing should be hurt if I connect them together.
          Find Nedry!
          • pentium
            • Mar 2006
            • 2778
            Okay, I'm into service mode and I ahve not messed with anything yet. There are very few trimmer pots on the TV (just focus, screen, H.Stat as well as the yoke controls and that's it) and it's all menu driven from an OSD (refer to page 44 here).
            Unfortunately the service manual mentions nothing about kine adjustment.
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              I tried very lightly messing with the settings but it still looks pretty ugly.
              Find Nedry!
              • weirdlookinguy
                • Sep 2007
                • 1638
                Any Sony remote should work, Sony is famous for all of its remotes operating all of its TV's. I bought my mom a cheapo 19" Bravia LCD for her bedroom last year, and the remote that came with it operates my 1992 20" Trinitron.
                It goes without saying but a Trinitron in good shape bangs out one hell of a picture.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  surprised its not just blinking at you.crt is probably worn out.yours is opposite of most though.green tends to go weak.they dont rejuvenate well either.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    What about increasing the heater voltage?
                    It's an old repairman's trick to squeeze some more life out of a worn tube.
                    Not a long term solution or one I would use personally but it will force some more electrons off the cathodes to verify if the tube is worn.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      you dont have anything to lose.add a turn or 2 to the heater winding.next stop the dumpster.but you might squeeze a bit more life from it.
                      just shot a 14" sony tube in a cnc pendant for a friend who needed the machine in a hurry.it was real sick but it rejuved well.have a good pull but i even had to tell him how to turn down the g2 because it got better yet after a few hours.this is the exeption though.sick sony tubes seldom respond well to anything.
                      • pentium
                        • Mar 2006
                        • 2778
                        That was my idea. Just crank up the voltage a little and that should pass me over until I can afford a decent LCD. However I don't know how to turn the voltage up. Like I said, a lot of the settings are cmputer controlled and not visually adjustable on the boards.
                        Find Nedry!
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          disconnect the heater line from the board.use a length of wire to make a turn or 2 around the fly core.connect in series with the old heater line.raises the voltage a bit and (hopefully) gives better emission.or at least improve it enough that its no longer green.
                          • pentium
                            • Mar 2006
                            • 2778
                            Okay, I'll give that a shot.
                            Find Nedry!
                            • cmonkey
                              Sony Trinitron KV32FV27 Suddenly Dimmed
                              by cmonkey
                              A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
                              I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
                              I'd say I had it on for about 15 minutes or so and then lugged...
                              04-28-2023, 06:25 PM
                            • motorahead
                              Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                              by motorahead
                              Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                              After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                              10-21-2023, 03:50 PM
                            • ptcriserx3
                              Sony trinitron crt bowed and side color issues
                              by ptcriserx3
                              Hi
                              Ive got a vintage 2001 sony trinitron flat tube tv
                              The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                              See many images attached...
                              Just windering if this is not fixable or something i can correct without getting too invloved
                              Im trying to sell the tv
                              06-17-2023, 07:27 PM
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • gkolio
                              Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                              by gkolio
                              Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                              12-01-2023, 09:09 PM
