Samsung UN60J6200AFXZA
  • R_J
    • 9532
    Re: Samsung UN60J6200AFXZA
    This is an always on power supply, it does not use a seperate circuit for standby. I suspect you may have shorted the A13V not the ps_on, so start by checking for a shorted output diode, DM851, DM853~DM856
    Using HOT GROUND )JP823/JP824) check the dc voltage on SP7 (DM810 Anode) This is the main ic VCC voltage
      • 12086
      • U.S.
      if all that checks out theres a bunch of resistors on the underside to test, one of the ic's on the underside could be bad.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Going to need better pictures of power board.
        • tahoe
          • Jan 2012
          • 18
          ok, have to start with standby, so unhook all cables from powerboard, then plug the power cord into powerboard, see if standby is there.
          No STBY =0V with just the power cord plugged in
          • tahoe
            • Jan 2012
            • 18
            R_J
            You could be correct on shorting A13V
            All diodes check good EXCEPT DM851C , It has 3 pins and all are shorted (in circuit) using a multimeter in Diode mode.
            This IC is marked "B5C04 SDB1080". I googled SDB1080 and it turns out to be a "Dual common cathodeSchottky rectifier" correct?
            Will now order this part to replace....
            Also, since this part is suspected bad, checking hot ground, JP823 to SP7 would not show any voltage....correct? and when working, what should this VCC voltage value be?
            • tahoe
              • Jan 2012
              • 18
              #26
              See attached pictures...
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                Hi res picture.
                https://www.shopjimmy.com/search.php...ry=bn44-00775a
                And you doublechecked your fuse. Outputs are usually protected from shorts by their controllers.
                  • 12086
                  • U.S.
                  #28
                  Originally posted by tahoe
                  R_J
                  sure seems bad, I'd take it out and check it out of circuit.
                  • tahoe
                    • Jan 2012
                    • 18
                    #29
                    Hi res picture.
                    FUSE is OK
                    • R_J
                      • 9532
                      R_J
                      If DM851 is shorted it will shut down the power supply, There should be vcc voltage on the primary ic but it will be low as there will be no feedback voltage to keep it up. You may be lucky and it is only DM851 bad
                      • tahoe
                        • Jan 2012
                        • 18
                        #31
                        Out of circuit , pins 1 (anode) and 2 (cathode) are shorted. Now awaiting new rectifier delivery.
                        Also,
                        Befoe removing rectifier. DC voltage between JP823 and SP7 = 11.1V
                        • tahoe
                          • Jan 2012
                          • 18
                          #32
                          Until I get the new DM851 delivered, are there any other i can probe other than the diodes and restors which are already done? I am fairly competent with electronics (scope and multimiter in hand) but without a circuit diagram, I am "walking in the dark" without your guidance....��
                          • R_J
                            • 9532
                            There is nothing to check until you have the diode in place and the power supply is back in operation.
                            • tahoe
                              • Jan 2012
                              • 18
                              #34
                              Hi All,
                              Rerplaced DM851C, D9001C and Q9001C
                              The good news; The power supply works and the LEDs all light. Main Board & Tcon are all functional
                              The Bad News: the LCD screen is cracked.
                              Thanks for all your help and guidance.
                              If any one needs ALL known good working PCBs, Cables etc. I am willing to consider a reasonable offer.
                              Thaks again!
                              • tahoe
                                • Jan 2012
                                • 18
                                #35
                                Hi R_J,
                                Thaks again
                                  09-07-2024, 05:50 AM
                                • cubytus
                                  Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                  by cubytus
                                  Hi to all,
                                  I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                  I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                  Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                  01-10-2024, 01:26 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
