Samsung UN60J6200AFXZA
  • Jason616
    • Sep 2016
    • 99
    What would cause this black line on the screen ?
    I reseated the ribbon cables but the line remains .
    Any ideas ?
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN60J6200AFXZA
    Static vertical lines are bad panels and not repairable. Google the Sony Tcon Training Manual.
    • Storyteller12
      • Jun 2020
      • 625
      These j series panels all seem to have this problem.
      I have 3 with the same line on the left side as well.
      • tahoe
        • Jan 2012
        • 18
        Default Re: Samsung UN60J6200AFXZA....no backlights but a picture
        Hi I need help with a UN60J6200AFXZA
        - installed New LED strips from Shop Jimmy..
        - No Backlights when Main Board is disconnected.
        - Replaced LED Diode, D9001C and MOSFET Q9001C
        O Volt reading (between Black and Grey wires on LED connector) when LED cable is disconnected
        - Replaced QP801CS and QP802CS
        Still O Volt reading (between Black and Grey wires on LED connector) when LED cable is disconnected
        Any ideas?
        thanks
        • dskall
          • Oct 2016
          • 2905
          • usa
          Need some pictures. And picture of connector with voltages.
          • tahoe
            • Jan 2012
            • 18
            Hi DSKALL,
            Here are the details on my Samsung UN60J6200AFXZA.
            Symptom:
            When Tv turned on, no backlight, has sound and does have an image when I used a flashlight.
            What have I done so far:
            a.) Replaced bad LEDs with new ones from ShopJimmy...did not resolve symptom
            On Power Supply Board BN44-00775A
            b) Replaced Diode D9001C and MosFet Q9001C...did not resolve the problem
            c) Replaced QP801CS, QP802CS and CP805...did not resolve the problem
            Disconnected Mother board then
            Voltage readings at present with the above replacements:
            STBY=0V with reference to chassis GND.
            With the LED Connector removed
            On Connector: CNL802
            pin1+ to pin 4:S- = 0V
            pin6:S+ to pin 9-=0V
            STBY =12.7V
            Voltage on either Side of D9001C = 0V
            On Connector CNM803
            Pin 2: UD= 0Volts
            Pin 4: PWM_BLU=0Volts
            pin 6: PS_ON=0Volts
            Pin 8: GND = 0Volts
            Pin 10: GND = 0Volts
            Pin 1: A13V = 0Volts
            Pin 3: A13V = 0Volts
            Pin 5: A13V = 0Volts
            Pin 7: A13V = 0Volts
            Pin 9: GND = 0Volts
            Fuse test good
            Can't get the high voltage on ConnectorCNM803
            Any help/guidance will be appreciated
            • tahoe
              • Jan 2012
              • 18
              Hi DSKALL
              I have to update the above voltage readings as follows.
              Before the voltages all went to zero, and thru the probing process, i accidentally Shorted Pin 6 (PS_On) and Pin8 (GND) on the CNM803 connector.
              Before this occured, the readings were as follows
              STBY=12.7V with reference to chassis GND.
              STBY =12.7V
              Voltage on either Side of D9001C = 417V
              On Connector CNM803
              Pin 2: UD= 2.4Volts
              Pin 4: PWM_BLU=3.4Volts
              pin 6: PS_ON= 4.1Volts
              Pin 8: GND = 0Volts
              Pin 1: A13V = 12.8Volts
              Pin 3: A13V = 12.8Volts
              Pin 5: A13V =12.8Volts
              Pin 7: A13V = 12.8Volts
              Pin 9: GND = 0Volts
              So....I now have 2 problems.
              1. recovering the state of the powersupply to the condition before the accidental short
              AND
              2.How to get the High voltage to the known good LEDs
              Thank you for your help
              • tahoe
                • Jan 2012
                • 18
                Hi DSKALL
                STBY =12.7V
                On Connector CNM803
                Pin 2: UD= 2.4Volts
                Pin 8: GND = 0Volts
                Pin 9: GND = 0Volts
                AND
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Shorting ps-on probably turned off power supply. Should come back up when you press power button. Did you test backlights with a tester after you installed them?
                    • 12274
                    • U.S.
                    since theres a question now, plug everything in as normal thats with all boards hooked up, then do this test, just like it is to see what you are getting: report the voltages you have in standby(tv plugged in) and when you power on the tv, report both conditions, as in: pin number, expected voltage and your actual voltage, example pin 1 ps-on, off 0volts, on 3.5volts.
                      • 12274
                      • U.S.
                      a question, are the original backlights bad?
                        • 12274
                        • U.S.
                        did you very carefully check the voltage between the legs of the big filter caps on powerboard? CAUTION DEADLY VOLTAGE in the hot/primary side of the board, normal is around 165 in standby and around 390 when tv powered on. If your meter is not autorange, you need to set it at 200 or next higher vdc.
                        • tahoe
                          • Jan 2012
                          • 18
                          Pressing power button does not turn on power supply.
                          I tested the new leds, each strip, with 27V batteries
                          • tahoe
                            • Jan 2012
                            • 18
                            Yes, they are
                            • tahoe
                              • Jan 2012
                              • 18
                              ON STBY (Since the PS is not turning on) voltage= 160.7V on both CP807 and CP806
                              • tahoe
                                • Jan 2012
                                • 18
                                Pluged everything back together...
                                STBY= 0Volts
                                All Pins read 0 Volts no red light indication of teh Power coming on.
                                Perhaps teh rectifier circuit is bad? I have no schematics so cannot probe down to the component level...
                                Any Help appreciated
                                • tahoe
                                  • Jan 2012
                                  • 18
                                  All cables put back into position.
                                  With Power applied,
                                  STBY = 0 volts
                                  All pins on connectors to main board and LED strips =0Volts
                                  Checked new LEDs fro Shopjimmy all tested good each with a 27Volt battery
                                    • 12274
                                    • U.S.
                                    ok, have to start with standby, so unhook all cables from powerboard, then plug the power cord into powerboard, see if standby is there.
                                      • 12274
                                      • U.S.
                                      make sure the screws holding the board down are not loose as they are also the grounds.
                                        • 12274
                                        • U.S.
                                        can check for standby voltage on dm851c, see the big stb:8v, on 13v printed in big letters on the board? others things to do, check all diodes in diode mode, probe on each leg, expect around .5xx one way, reverse probes, expect ol or l, check the resistors too, youtube is your friend for how to videos, also check the bottom of powerbard solder joints, check below.
                                          09-07-2024, 05:50 AM
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
