75UK6190 blank screen, shorted caps on panel strips
  • mecha1166
    • 37
    I have 2: 75UK6190 units. One has a broken panel - it lights up and shows a bit of graphics. The other LG tv lights up but has no video. Turns on/off ok, and I swapped all the boards to check them all. I exposed the strips on the bottom of both panels. I tested the caps along the LED strips on the bottom of the panel. About 12 smd cap chips on the tv with no video, test shorted. I talked to LG tech support but they do not repair to this level, they just replace the panel. Now, there is a Philips mainboard that a smd capacitor chip shorts and causes a squeal from the power supply, and the fix is to simply remove it. Has anyone had experience replacing the smd capacitors on LED panel control strips or repairing them?
  • mecha1166
    • 37
    Re: 75UK6190 blank screen, shorted caps on panel strips
    Here is some LED panel strip repair information:
    https://www.vislcd.com/full-repair-g...creen-failure/
    • mecha1166
      • 37
      I would not apply voltage to see what might be shorted like this, but shorted caps are talked about here: https://www.youtube.com/watch?v=YsZiUzqIZeE
      • dskall
        • Oct 2016
        • 2905
        • usa
        If you have shorted caps doesn't mean they're all shorted. Or even that it is a cap that is shorted. Voltage injection is probably the easy way to find short.
        • mecha1166
          • 37
          Thanks for your reply & help. I have a good (but cracked) panel and the one with possible shorts. I'll sit down and start pulling components and comparing readings, to locate the short. I have replaced chips on t-cons before. I'd hate to throw away an uncracked panel, or sell it for $50 to the Mexican buyers that come through each month.
          Thanks,
          jim
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • EazyBone
            Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
            by EazyBone
            Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
            Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
            Now what exactly do I need to do in order to attempt to fix this issue?
            do I have to take each one...
            12-24-2023, 06:59 PM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • dicky96
            HP Elitebook Screen blank - backlights but no image
            by dicky96
            Hi guys
            I'm trying to fix this laptop screen
            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
            OK so I have the original screen which works but has lines across the bottom quarter of the screen
            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
            04-28-2021, 07:30 AM
          • kotel studios
            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
            by kotel studios
            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
            State I got it in:
            Squealing from the PSU
            After logo I get a blank screen
            After 10 seconds of having a blank display w/ backlight the TV dies
            Give it 7-10ish seconds again and it starts to bootloop.
            What I did so far:
            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
            Checked all voltage rails:
            5VSB - 4.8V
            AMP+13V - 14.4V
            13V - 12.98V (in manual 12V)...
            09-21-2025, 02:00 AM
