TV "BLAUPUNKT"32/122I-GB-5B-HBKU-EU - ok standby - blue led on for a few seconds
  • truztruz
    • Nov 2021
    • 4
    • italy
    Hello to all,
    I'm trying to repair a TV model "BLAUPUNKT" 32 / 122I-GB-5B-HBKU-EU with mainboard TP.MSD309.BP75.
    Red standby is present.
    By pressing the power button, the blue led lights up for several seconds (about 6 seconds) but no sign of TV life (no backlight and no video signal on the panel (verified with a flashlight)
    The LED then returns to red and then returns to blue and so on (the flashing is not fast, but as mentioned, several seconds pass between red and blue)
    I measured the voltage on the main output connectors on the inverter and I have between 24 and 24.7 volts. Are these voltages correct? Should the backlight turn on?
    The capacitors are not swollen but anyway I will try to replace them as soon as I have the opportunity to buy them.
    They are n.2 capacitors of 25v and 470uf + n.2 capacitors of 35v and 330uf + n.1 capacitor of 16v and 470uf.
    If I change them do you advise me to respect the original values or to use higher values?
    Did you happen to have similar behavior on this TV?
    I add that, in the various attempts to switch on, the TV miraculously turned on only once last week (tested for about a minute the menus and the panel were ok), then after turning it off no more worked.
    I hope for your kind help.
    Thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: TV "BLAUPUNKT"32/122I-GB-5B-HBKU-EU - ok standby - blue led on for a few seconds
    Need pictures of back of TV and good close ups of boards. I would say you have a power board problem. But need pics.
    • lotas
      • Jan 2016
      • 4474
      • Russia
      More likely a problem with the firmware in the UF11 spi flash 25Q64.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would try heating up board and see if it comes on.
        • ducky29
          • Dec 2015
          • 370
          • Europe
          Thats a eeprom/firmware related problem. Try freezing the eeprom and then check again. But its better if you replace it with a programmed chip or you flash the firmware.
          • yokoono
            • Apr 2010
            • 475
            Firmware problem. If you have a programmer I will give you the software to program the memory. Check if the panel has LC320DXN (SF) (R2)
            • truztruz
              • Nov 2021
              • 4
              • italy
              thank you all. It really was a firmware problem and after reflashing the chip now tv works again. Never seen a software corrupted tv until today. But how can this happen ? Bad eeprom ?
              • lotas
                • Jan 2016
                • 4474
                • Russia
                Power surge, unstable power supply (ripple), high temperatures, software failure, malfunction of the flash itself.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4277
                  • Italy - Milan
                  much probably power surge or tv left off for too much time..
                  • Egidio85
                    PS5 EDM-033 blue led 1 seconds power off
                    by Egidio85
                    Hi, I have a ps5 EDM-033 that lights up blue for 1 seconds and then turns off
                    the start sequence is correct, it reaches 320ma and then drops to 10ma
                    checking the card I didn't find any shorts
                    Reading the codes via huart gives me the following errors:
                    01 31/05/2025 10:48:09 80801F12 Low Known Unknown 80801F12 (Kernel) - Report Findings - 1 sec blue light
                    I-(OK 00000000 80801F12 000405B3 FFFF0005 00000100 2013 0036 3840 0000:FE)
                    26 28/09/2038 01:45:59 80801608 Low Known Unknown 80801608 (Kernel) - Report Findings
                    I-(OK 00000000...
                    05-31-2025, 10:49 AM
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-07-2024, 05:50 AM
                    Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                    09-07-2024, 05:00 AM
                    Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
