lg 42plasma horizontal line
  • cadiman
    • Mar 2010
    • 397
    I picked up another l/g 42 plasma It has a great picture except for two horizontal lines (pin stripe). One is about 6" from the top and the 2nd is about an inch from the bottom. I would guess at the y buffer or connections from y buffer to pdp. I hope the double line is a clue (pattern)?
    Cadiman
  • NxB
    • Feb 2009
    • 1595
    Re: lg 42plasma horizontal line
    There is a service manual in my y board thread. I think it covered this. What is your specific tv.
    • Wizard
      • Mar 2008
      • 2296
      Not necessary. Replace both Y-buffer boards that for that lines. Be GENTLE with unplugging and plugging orange flat cable! Do this before undoing any of the screws holding Y-buffer board in.
      Cheers, Wizard
      • cadiman
        • Mar 2010
        • 397
        I removed the y buffer board (one board) first then removed the flat cable. It was easier to hold the ribbons. These were pretty tight. also as you have said before the 4 leds on the control board only tell you something is running. I have worked on about 5 of these and the last led is never lit up. This is a pdp42x3 made for a vizio. Is this chip failure, connector, or solder failure? Thanks again for your help Wizard!
        I will check out said thread. Thanks NxB!
        Cadiman
        • Wizard
          • Mar 2008
          • 2296
          IC failure. Blew a buffer for the line. Y-buffer boards are replaced as whole.
          Cheers, Wizard
          • cadiman
            • Mar 2010
            • 397
            I replaced the buffer board and still have the same lines. This can`t be good.
            This will make a nice board tester though!
            • Wizard
              • Mar 2008
              • 2296
              Oouch! Still, there are plenty of plasma tv using same panel.
              Cheers, Wizard
              • mockingbird
                • Dec 2008
                • 5488
                PDP4273?
                I think I have the same model as you, rebranded though.
                I'm curious, the spec for this TV says 1024x768... What resolution do you get through the VGA input?
                • cadiman
                  • Mar 2010
                  • 397
                  The l/g panel is a pdp42x3000 made for vizio. boards are used in lots of models (2006) date code
                  I will use this panel for some reverse engineering ( a good thing )
                  This panel is a 720p as far as I can tell. I have made enough money on 6 tvs so I will deal with the 100.00 loss on this one. I will learn alot with this tv now and will gain a great deal of info and training from it. Well worth the 100 bucks! Thanks for all the help!
                  Cadiman
                  • Ihandyrepair
                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                    by Ihandyrepair
                    Hi guys
                    I just started fixing 4k TV few months ago. so I am still learning a lot
                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                    then it started to show the ghosting white image.
                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                    it has 3 thin small boards at the bottom of the...
                    12-05-2022, 04:18 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • cubytus
                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                    by cubytus
                    Hi to all,
                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                    01-10-2024, 01:26 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • labello
                    Lg43UJ620V horizontal line
                    by labello
                    Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
                    02-20-2025, 02:52 AM
