Bush led40127fhdcntd possile firmware issue?
  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
    I will upload photos of the mb ,
  • titomno2
    Surface Pro 7 type 1866 PD controller firmware issue
    by titomno2
    Hi guys,
    Hope you are fine.
    I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
    The boot time is so long (up to 5-10 minutes).
    After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
    I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
    In the past I have found that if the update is a success, the boot...
    04-27-2025, 01:02 AM
  • tsitsos
    43 inch tv firmware issue.The board is cv338h-t42
    by tsitsos
    Hello all. I would like some help on installing a firmware on tv..
    4 days ago i changed a channel and the image became complete blue and the tv unresponsive. No matter what i did ( like unplugging the power , press the power button for minutes etc etc nothing helped) Then i had an idea to flash it via usb. The brand is very uncommon (smarttech) so i had hard time finding the right firmware. i ended downloading 2 just in case. I flashed the first one with usb and pressing the power button like 5 times. The installation was successful and tv worked ok with some little problems that right...
    03-11-2022, 07:32 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • Chrissygizmo
    panasonic tx-55fx555b firmware issue
    by Chrissygizmo
    Hi all, am posting this for a friend so I don't have any photos of boards or anything, I know I should have all the information at hand with photos etc but I just thought I would try to find him the firmware he needs, I saw a thread on here where a user named "Diah" sent links to "l3emarsh" for the same firmware...
    Basically, the standby light is constantly flashing & after reading posts on different sites I've come to the conclusion that it most likely is the firmware...
    Any help would be appreciated
    Thanks in advance
    07-28-2022, 05:16 PM
