LG OLED 55EG9100 TCON troubles
  • jfl2507
    • May 2020
    • 3
    So I've been having trouble with this TV for years. The symptom was every now and again the image would just freeze and sound would keep playing, a quick power down and power up would fix this until the next freeze. The problem went like this until it started displaying green lines and artifacts as well, also it would not even turn on until it was warmed up. I originally thought it was the main board so after ordering a new replacement it did not fix the issue. Next on the list was a TCON board, I could not find a new one at all, so I bought one that was compatible with my TV used, not exactly the same but description said it worked with my 55EG9100. When I installed it the TV would turn on again. But there were burned in images of a fox news channel and cloudy dark spots, colors way off. I thought I got a defective TCON so I ordered again another one this time matching the exact model my TV came with. Same results, though this time it had a different channel logo lol , the original still works and no burned images but it takes a bunch of tries and i have to warm up the TV for it to get an image.
    I've done a lot of reading and it does look like somehow my original TCON board has some settings that need to be transferred to the replacement, it looks like an expensive solution for that Jig interface. My question is if the settings are stored in an EEPROM chip I can desolder from one board and put it on the one I bought on Ebay? I am handy with electronics and can deal with most surface mounted components except re-balling a video chip lol
    I have some tools if someone can guide me in the right direction, basic multimeter, hot air station & soldering iron, Digital Oscilloscope. I am including a picture of the 2 TCON boards I bought top one is not exact match but compatible, bottom one is exactly like the original both work but give different screen artifacts. There is an 8-leg EEPROM chip on the left side corner if its as simple as swapping it from the original or is it more complicated than this? If there are any schematics for this TCON board out there that would be extremely useful
  • lotas
    • Jan 2016
    • 4859
    • Russia
    Re: LG OLED 55EG9100 TCON troubles
    But the firmware is most likely in flash and eeprom.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4539
      • Italy - Milan
      Well, watching some Oled tcon it seems them are different from lcd ones, not all, the p.supply part is much similar, the signal part not much, them have a real processor when in lcd not, so i would have expected an optional serial port for debug but i don't see any. Also the TP near the flash doesn't seem them are for an emmc but maybe a Nand or OneNand.. so flying wire connection is not an option maybe.. the only option that it could be for me is to deeply dive into service menu trying to find a download option to save customization data for tcon to an usb flash pen.. it surely needs a service remote or app.
      About original one, does it happens that defects shows at absolutely cold board?
      If you want to fix it i have a test for you maybe..
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        With older models the NAND and Eeprom software must be taken from the old defective t-con and uploaded into the new t-con. The NAND software for example is used for the mura clouding , see attached picture.
        Newer t-con only need the NAND software.
        • jfl2507
          • May 2020
          • 3
          Thanks for the input so far guys, To answer Davi, Original Board was working for 2 years with no issues other than an occasional freeze up a couple times a week. When board is completely cold it acts like a dead TCON, power supply clicks red light on bottom but completely black screen. Powering on and off for several minutes will eventually bring the screen though now random green lines and pixels will show up. The replacement boards work right off the bat, but a lot of MURA issues. I am thinking of biting the bullet and re-ball the flash chip. Its a BGA 63 chip so I am looking for a stencil with an 0.8mm pitch, I have a cheap BGA station I can use but will have to practice on lifting ram chips from old video cards to get comfortable with it haha. I do remember the voltage of Q21 was 3.5V when it was working and dropped to zero when it wasn't working but this was me fiddling with the meter at components near the power supply connector.
          A closer look reveal pads next to both EEPROM and flash chip, pads labeled for reading, writing, write protect ect. So if there is such a thing as a simple Arduino EEPROM programmer that can be attached to these pads though not sure about the flash chip lol.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            My question: how much you have used the replacement tcon boards? I'm not so sure the original one is defective, i'm guessing the fault could be both msin boards.. them are a tipical defect of LG..
            • Andrei_UK
              • Dec 2021
              • 30
              • United Kingdom
              Hi
              Do you have Idea how can I doo that to write to the new T-CON ( OLED55 C9 )
              The original T-CON it's definitely foult ( turn on TV all good but acter 30 sec power off )
              New T-con all works good exept with vertical bands which you can notice when gry pic ( like in your pic )
              Thank you
              • Andrei_UK
                • Dec 2021
                • 30
                • United Kingdom
                Hi
                The original T-CON it's definitely faulty ( turn on TV all good but after 30 sec power off )
                Thank you
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Have you tried reflowing main chip?
                  • Andrei_UK
                    • Dec 2021
                    • 30
                    • United Kingdom
                    No I didn't, you mean the big platinum chip ?
                    • Diah
                      • Feb 2013
                      • 6563
                      dont play with chips.
                      search after apache server to downgrade or roll up fimware on LG OS TV. here in this forum i wrote about it too.
                      if you downgrade or rolled up the firmware... it will match yours replament T-CON firmware part with the main firmware.. also if you send command IN_STOP it will match them and send refresh to t-con to remove any burn caued by T-CON
                      • Andrei_UK
                        • Dec 2021
                        • 30
                        • United Kingdom
                        Hi
                        Thank you for your suggestions, I will try find how to downgrade the firmware maybe a last solution, in this stage I have done IN-STOP few times and the WebOS apparently looks like factory reset , but still I got the vertical bands slightly vizibile
                        One question, it's the T-CON has eeprom chip? I Was thinking if I read/save the data from the old T-con and the writing to the new one .
                        Thank you again for any suggestions
                        • Diah
                          • Feb 2013
                          • 6563
                          Hi
                          yes you can
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            No I didn’t, you mean the big platinum chip ?
                            The chip on original t-con. Ok I'm replying to OP. Didn't see the change in posters to this thread.
                            • Andrei_UK
                              • Dec 2021
                              • 30
                              • United Kingdom
                              No I didn't, I will try the option by rolling back or downgrade if posible if not I waiting for the eeprom flash usb and try to read the 8pins chip from the t-con ( hopefully it's the eeprom chip one )
                              • lotas
                                • Jan 2016
                                • 4859
                                • Russia
                                No I didn’t, I will try the option by rolling back or downgrade if posible if not I waiting for the eeprom flash usb and try to read the 8pins chip from the t-con ( hopefully it’s the eeprom chip one )
                                432FK = 24C32 (TSSOP8) - 1.7 V to 5.5 V EEPROM
                                F59D1G81A - 1 Gbit (128M x 8/ 64M x 16) 1.8V NAND Flash Memory
                                • Diah
                                  • Feb 2013
                                  • 6563
                                  this is no need at all... we do know the firmware of the LG contain NFC.bin part where it will saved at T-CON eeprom.
                                  the other parts of the firmware will be saved at mainboard eeprom and micon. micon communicated with T-CON eeprom.. if there grab between micon and T-CON eeprom version will cause this burn.. we had always successful story when downgrade or rolling up the firmware on PC Apache server... so all firmware parts will match. no soldering nothing hardware work. easy way log in EZ adjust service menu or at IN_Start we will find all version we talking about and also the ability to see when & how many there pixel refresh has being done.
                                  • Andrei_UK
                                    • Dec 2021
                                    • 30
                                    • United Kingdom
                                    I think you got right about the version on the IN-START , I maybe mistake but I can see two versions at the OLED info different number between panel and new t-con I will update tomorrow the version of dose two , I will try to find how to post some pictures here ( I m new on the account) you guys to see about the vertical bands and some info from IN-START
                                    • Andrei_UK
                                      • Dec 2021
                                      • 30
                                      • United Kingdom
                                      Some pic attached
                                      • Diah
                                        • Feb 2013
                                        • 6563
                                        Some pic attached
                                        can you show us here same page IN_START of the original T-CON in place ?
                                        did you sent IN_STOP before while original T-CON in place ?
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
