LG plasma MZ-42PZ44 YSUS short
  • PowerAmpFreak
    • 977
    • Sweden
    Hello. A main fuse on the YSUS board was blown. Dead short after fuse to secondary ground. See attached pictures.
    What's hiding under the big heatsink? A hybrid IC?
    Anyone know of "usual" stuff that blow on the YSUS module?
    Saw a small electrolyte like 100uF/50V going round top (bad), don't think this cause fuse blow though...
    Any input is warmly appreciated.
  • cadiman
    • Mar 2010
    • 397
    Re: LG plasma MZ-42PZ44 YSUS short
    If you search old posts for plainbill and myself you will find alot of info on l/g boards. This chip is hard to replace. I have done these and have gotten pretty good at it. I could talk you through it. This ic is 40.00 on ebay. The blown fuse means you need to check the y buffer board for shorts. There is a white sticker on the y sus board with the part number. type the part number in ebay and that board will come up.
    The part number for the chip is on the heat sink (type into ebay) should cross to an stk 720 ? This will come up on ebay too. Need to replace caps for 15-18 volt supply to ic Wizard would know the best way to check the buffer board.
    Cadiman
    • PlainBill
      • Feb 2009
      • 7034
      You should be able to determine if there is a hybrid under the heat sink by looking at the back of the board. Two rows of pins about 2.5" apart are a good clue.
      Someone on eBay is selling the hybrids for $40, but they don't list that as a module they fit. Someone is selling the complete Y-sus on eBay for about $72.
      PlainBill
      • PowerAmpFreak
        • 977
        • Sweden
        I suspect replacing the entire Y-SUS board will be needed.
        Of course some questions arise:
        What may cause the Y-SUS board go short?
        Should a new Y-SUS board bring the tv back into operation?
        I don't want to end up placing a new board and just hear it boom again...
        Could the panel itself be bad and short out the Y-SUS board which then fails?
        Could a powersupply problem end up in a shorted Y-SUS board? The output voltages from the powersupply is measured and seems ok.
        • PlainBill
          • Feb 2009
          • 7034
          Y-sus boards can blow by themselves; they ARE handling high voltage and current. They also interact strongly with the buffers. The Y-sus board plugs into the buffers. Check each of the chips on the buffer boards carefully for damage - in particular a pinhead sized crater blown in the top of one. If you don't find any sign of damage you have a decision - replace the buffers anyway, or risk blowing the replacement Y-sus.
          PlainBill
          • NxB
            • Feb 2009
            • 1595
            Smell the hybrid IC. If its not burned, you can fix most of the other stuff on the board. Its better than replacing.
            • PowerAmpFreak
              • 977
              • Sweden
              No smell. The board is *dead* short zero ohms...
              I would need a schematic, this board seems to be in use in many different models and brand names, maybe anyone has a schematic for it?
              There are a lot of circuits working directly of the VS supply, so there may be hope for a good hybrid after all.
              • cadiman
                • Mar 2010
                • 397
                number one failure is y sus no picture (chip failure) check 15-18v power( marked on baord ) check caps This chip needs larger heat sink, cooling fan
                number two failure is z sus... dark picture
                third common failure is the control board.. patterns in picture/no picture
                Every tv I have replaced ( 4 ) bad z board already had a y sus board replaced
                The y sus board is the hardest working board in the tv. Thus the most common failure.
                Do you want to learn something or just fix the tv?
                If you want to learn, replace chip and see what happens
                If you just want to fix the tv replace the y sus board and the buffer board.
                If you have never seen this tv working you may find it working with a screen that has some burn in.
                Plainbill and Wizard always have the best advice.
                Cadiman
                • PlainBill
                  • Feb 2009
                  • 7034
                  Cadiman
                  Correction!!! Wizard has the best advice. PlainBill sometimes gets it right, also.
                  PlainBill
                  • cadiman
                    • Mar 2010
                    • 397
                    I just picked up one of these with a bad panel. I am gonna check out the boards. let me know if you need anything.
                    Cadiman
                    • PowerAmpFreak
                      • 977
                      • Sweden
                      Thanks, I found a cheap YSUS board on ebay. In a few days I know if I need more stuff.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Per Wizard, check the y buffers very carefully for any sign of a blown chip (pinhole or crater) before inserting the Y-sus card.
                        PlainBill
                        • PowerAmpFreak
                          • 977
                          • Sweden
                          Carefully checked the buffer ic's, no sign of damage. Is it common that buffers go when ysus shorts?
                          Generally, would someone explain how the bits holds together? I mean all output power that ysus board provides, how is this handled by the buffers?
                          I can't figure out how on earth the buffer ic's without any heatsinking would have a chance to do high power work..
                          Plasma is pretty new for me, but been doing ordinary CRT tv service and powersupply service for about 15 years.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            It's amazing to me too. But remember that power handled is not an issue; it's power dissipated.
                            PlainBill
                            • cadiman
                              • Mar 2010
                              • 397
                              I have an insignia (l/g) and it has heat sinks on the buffer chips. It also has a cage blower fan that pulls air through the panel. Very few of these dissipate heat properly as you will see.
                              • PowerAmpFreak
                                • 977
                                • Sweden
                                Wizard, I wonder how big chance there are that Y buffers are blown as a result of YSUS board failure? I've examined the buffer chips carefully, there are no sign of blown chip. Is it common that the buffer chips are the cause for YSUS board failure?
                                I just want to get an idea if I dare to put another YSUS board in without changing Y buffers.
                                • NxB
                                  • Feb 2009
                                  • 1595
                                  Mine looked undamaged and they were fine.
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    Ohm the power planes (all of them vs ground), if not too low in resistance, probably ok. Get good YSUS board.
                                    Cheers, Wizard
                                    • PowerAmpFreak
                                      • 977
                                      • Sweden
                                      New YSUS board arrived and replaced. But there are some strange behaviour of the screen. May it be necessary to trim the voltages on the new board?
                                      Here is what happens:
                                      Set comes on, a decent picture shows up, but colours are fading in and out slightly, white OSD text fades from white to red, to blue and back to white...
                                      Is the set all toast?
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        Preset the YSUS two pots to exact position as old.
                                        Cheers, Wizard
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • triplefour
                                          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                          by triplefour
                                          Samsung UN55ES7003
                                          made house call.
                                          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                          psu has self test feature.
                                          disconnected from mainboard.
                                          determined PSU ok BL ok.
                                          suspect mainboard.
                                          disconnecting tcon has no change on operation.
                                          markings on mainboard:
                                          BN97-06531P 0151
                                          BN94-06123R
                                          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                          for 54$
                                          second house call:
                                          with replacement mainboard, tv turns on, has sound,...
                                          07-13-2022, 03:53 PM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
