LG OLED Problem 55EG960V
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    hi guys I have an LG OLED TV 55EG960V
    that started to display garbled images while menu icons was ok.
    and now it no longer turns on.
    could this be a bad main board ?
    ive tried to source one but so far im having no luck.
    so basically I have a 55" doorstop at the moment.
    can anyone advise what I can look for / check ?
    thanks
    Jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • TeslaMichael
    • Oct 2020
    • 102
    Re: LG OLED Problem 55EG960V
    If it would be the T-Con, then everything would look broken. because it goes from Mainboard to T-CON and the t-con cables are going into Panel. if i'm not wrong, the t-con does display the volume, and other things.
    i'm thinking too, that this could be a mainboard issue.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4343
      • Italy - Milan
      Make a CPU reballing..
      • jasonr2000
        Advance Tech
        • Nov 2013
        • 209
        hi guys thanks for the replies.
        ive had no luck so far sourcing a mainboard for this tv.
        and to be honest I wouldn't know where to begin reballing the CPU on there or finding out which one is the CPU lol,
        one more thing is there anyway to display the colours bars on these tv's ?
        thanks
        Jason
        Samsung UE46D6530
        Samsung BD-F7500
        Samsung HT-ES6200
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4343
          • Italy - Milan
          For the reballing you can research locally or the nation for reballing service centers
          for the autotest, i know in lcd displays there's a method to show it by simply suplying power to it but not any video or other signals. Try the same with this..
          PS: my previous post advice is not a solution but a diagnosis due to high percent of those problems in lg tv..
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            hi Davi.p
            thanks again for the reply.
            I have tried to power it on without the mainboard LVDS cables connected
            but nothing happens.
            is it looking for a power on signal or something ?
            thanks
            p.s as the mainboard just causes the power logo to blink while connected I don't think its actually turning on the PSU and doing anything ???
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4343
              • Italy - Milan
              Just to clarify, i mean supplying power to tcon, so i guess 12v+24v, and nothing other
              to take those tensions by the internal PSU you must turn on a pair of control signals.
              So post a photo of serigraph tables around connectors on PSU..
              • jasonr2000
                Advance Tech
                • Nov 2013
                • 209
                Sure here is the pin out to the main board connector
                Samsung UE46D6530
                Samsung BD-F7500
                Samsung HT-ES6200
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4343
                  • Italy - Milan
                  Just put a jumper 3,5v-PWR-ON-DRV-ON-12VT-ON
                  post PSU model number
                  • jasonr2000
                    Advance Tech
                    • Nov 2013
                    • 209
                    Sure here is the model number / part number
                    EAY62992602
                    Samsung UE46D6530
                    Samsung BD-F7500
                    Samsung HT-ES6200
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4343
                      • Italy - Milan
                      So by the photos i don't manage how to.connect all the power supplies without connecting data
                      • lotas
                        • Jan 2016
                        • 4620
                        • Russia
                        Eay62992602 psu
                        • jasonr2000
                          Advance Tech
                          • Nov 2013
                          • 209
                          Originally posted by lotas
                          Eay62992602 psu
                          thanks for the attached PDF
                          that will help troubleshoot the PSU
                          now to find one for the main board would be good
                          EBT64032668 / EAX66685201
                          thanks again
                          Samsung UE46D6530
                          Samsung BD-F7500
                          Samsung HT-ES6200
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            Hi again
                            The display glows so I assume that's ok ?
                            It don't display colour bars or anything but there could be it needs a signal or something from the main board and as that's not powering up
                            It's not likely to so would that rule out the display as being the issue ?
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4343
                              • Italy - Milan
                              Starting from my point of view of bad CPU the display must be ok, but the test you have done it is not a self test so no sure answer
                              • jasonr2000
                                Advance Tech
                                • Nov 2013
                                • 209
                                Well I know there was no physical damage to the display it just started off with a garbled image on HDMi and the apps and then not powering up.
                                So I would say the main is the problem.
                                But I can’t source one to test.
                                I’m still trying to find someone to reball the cpu
                                But I have found some dead shorts coming from the cpu on several caps
                                Samsung UE46D6530
                                Samsung BD-F7500
                                Samsung HT-ES6200
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4343
                                  • Italy - Milan
                                  How do you know if them comes from CPU without a schematic? If you think that you can post photos of what you are measuring but I'm convinced you are wrong due to the progressive damagement
                                  • jasonr2000
                                    Advance Tech
                                    • Nov 2013
                                    • 209
                                    The sectioned circled is where I find the dead short to ground
                                    Samsung UE46D6530
                                    Samsung BD-F7500
                                    Samsung HT-ES6200
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4343
                                      • Italy - Milan
                                      Check if the top 3 terminals of those components and bottom 3 are connected together..
                                      • jasonr2000
                                        Advance Tech
                                        • Nov 2013
                                        • 209
                                        The bottom ones are all connected to ground but the top ones on the first two are not.
                                        But the 3rd one is grounded
                                        Both sides
                                        Samsung UE46D6530
                                        Samsung BD-F7500
                                        Samsung HT-ES6200
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72EEBB4SO boardview and 14 OLED BMF-72EEBB4SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
