SONY KD-43X8305C - Not booting after software update
  • Russ17
    • Mar 2018
    • 125
    I have been given a SONY KD-43X8305C Android based 43" 4K TV.
    It received a software update which failed and then failed to boot after.
    I have tried holding Power and Volume down (-) then applying AC power, multiple times, with no success.
    The backlight is off, the main status LED is Off, the Mainboard heat sink gets slightly warm if left on for more than 30 minutes, showing it is getting power.
    PSU has normal outputs. Screen appears blank even with a torch test and no start up sound from Android is heard when powered on.
    I have tried to force the software update with the Sony procedure but no success.
    @Diah - any advice as what to try next?
    I have a heat gun (solder rework station type & paint stripper type) and some re-work flux, is it worth trying the BGA heating fix?
    Thanks in advance.
    Russ
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4426
    • Italy - Milan
    Re: SONY KD-43X8305C - Not booting after software update
    No bga rework, it is clearly a software issue, the only way is to reprogram firmware by rs232 or directly on main flash, having the right file.
    • Russ17
      • Mar 2018
      • 125
      Hi Davi.P
      I have a software package from Sony, which was the one I tried to apply using a USB stick. Can that package be used by RS232 to re-program the system? If so, can you describe how to do this, as I am new to this type of issue.
      Regards
      Russell
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4426
        • Italy - Milan
        No, the archive you are describing is an update, by rs232 needs an entire dump, anyway trhough serial it is only theorical, often is nearly impossible due to restrictions and lack of instructions/guides.. sorry..
        i was watching today a possible hardware to program the emmc flash without spending much , hoping it will work..
        • Russ17
          • Mar 2018
          • 125
          So it sounds like I either need to have the board repaired (have the emmc chips(s) replaced with pre-programmed ones) or buy a second hand board (very hard to find).
          Seems a shame to have to scrap such a good TV..........
          Thanks for you help Davi.P
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4426
            • Italy - Milan
            These days i'm watching some possibles chooses for cheaply reprogram directly the flash and maybe without a dump from an unknown place, there is much to study and test, now i'm still with repair due to recent house change.. as a emmc reader an extremely cheap SDcard reader, for dump a repaired original dump...
            • cheeky2
              • Dec 2012
              • 337
              • uk
              Not hard to find but expensive nevertheless.
              https://www.ebay.co.uk/itm/255195981274
              at £90!
              • William1967
                • Nov 2017
                • 214
                • Netherlands
                The EMMC has reached it's "end of life" , therefor it must be changed with a loaded EMMC. Reloading the old EMMC will not work. Buying a second hand works but how what is the status of the EMMC on that board...
                The next problem is when you swap the EMMC the Netflix app and CI+ connection will not work. Done several of these mainboards and all had the same problem.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4426
                  • Italy - Milan
                  You can see the end of life status by the log? I previously fixed a pair of tv with software problem, repairing the orginal firmware and them are still working it seems.. no returns..
                  • Russ17
                    • Mar 2018
                    • 125
                    The CI is not an issue, but losing Netflix would be.
                    Is it because it is not part of the software that is reloaded?
                    • ducky29
                      • Dec 2015
                      • 369
                      • Europe
                      Do you basically flash a good emmc dump into the new chip and you solder it back on the board? No fooling around with other tools or modifications? I have seen couple of ebay sellers going up to 100gpb for this board.
                      • gabontz
                        • Dec 2021
                        Did anyone managed to get a fix around this?
                        Did anyone found out why is this happening if you replace the eMMC and program it with a backup from another board?
                        Tia
                        • Russ17
                          • Mar 2018
                          • 125
                          Tia
                          I have not solved this one - Seems eMMC chips are prone to this, and this issue has even affected Tesla Cars as they use a similar device.
                          The only real solution is to replace the whole board, but that too will likely suffer the same fate eventually.
                          Due to the age (2015), it doesn't make economic sense to buy a main board for £100+, which will maybe die in a few years at most.
                          • eclectric
                            Sony Bravia KDL-70W850B T-CON board / software update issue
                            by eclectric
                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                            05-23-2022, 01:25 AM
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
                          • sigmeyer
                            Need a firmware update software for grundig gbj-9146
                            by sigmeyer
                            I have a customer complaining that tv has a software issue .. He tried to update with some other software but first he had issue of no picture , then after another update he had no sound but had picture. So its pretty clear its a software problem.
                            So im trying to help him out and find him the update software
                            TV in question:
                            Grundig new york 46 3d WEB((GBJ 91 - 46))
                            Panel - LTA460HQ08 // 056D46-SS10
                            I have found a softwareupdate_gbj7246.zip file online , but obviously is not the same , it is for the same panel but not the same model ..i cant even download it...
                            03-10-2021, 04:16 PM
                          • Catmouse
                            HP EliteDesk 800 G4 - Orange LED behind Mainboard, not booting after BIOS Update
                            by Catmouse
                            I have 2 Elitedesk 800 G4 which have stopped working after a BIOS Update. It was doing the updates and instead of rebooting automatically it just stayed off and I was left with an orange LED being on behind the mainboard and no reaction at all when I hit the power button, it seems to be completely dead.
                            Removing the battery, pressing and holding the yellow button on the MB didn't do anything either.
                            Others have updated fine without any such issues.
                            When googling I've found other people having the same issue with the orange LED being on and the PC also...
                            10-29-2024, 04:27 AM
