Panasonic 42”Plasma TH-42PX77U with color vertical lines
  • ecking767
    • Oct 2009
    • 492
    Hello, I'm hoping finding this Panasonic 42” Plasma TV in the trash dumper @ work will be me some joy. The model number is a TH-42PX77U, I haven't cracked its open yet because I'm a little new when it come to Plasma television. I have work on LCD TV and LCD Monitors but no Plasma. I uploaded a picture of it. It power on fine but, there are multi color lines in the screen. On the left side of the screen you can see an image of what input is being selected.
    Question: Do this appear to be a bad screen?
    I will open this TV this weekend and post more pictures
    Not sure what to look for?
    Any input will help?
    Ecking767
  • PlainBill
    • Feb 2009
    • 7034
    Re: Panasonic 42”Plasma TH-42PX77U with color vertical lines
    Ecking767
    Wizard is the expert, but if I have absorbed what he has tried to teach us, those are the signs of a bad panel.
    PlainBill
    • cadiman
      • Mar 2010
      • 397
      If there are virticle lines EVENLY (pattern) across the screen It may be the control board. If only one or two at odd spaces (no pattern) Wizard says bad pdp. This is where the driver is part of the pdp and not just plugged into it. I have seen some pdps (few) where you can repair it. It depends on the year and brand of the pdp. I don`t have a list, but wish I did.
      Cadiman
      • ecking767
        • Oct 2009
        • 492
        Thanks PlainBill and Cadiman for your input,
        After looking around inside this plasma TV I didn't see anything out of place or any loose connections. I wish I was able to detemine for sure if the plasma panel itself is bad. I have search eBay for parts and I might invest into Main Logic Controller D Board.
        PN:TZTNP01LPTU TNPA4133AD AD-
        The C1 & C2 BUFFER BOARD there wasn't much to it so I will swap that second. (maybe?)
        I will keep your all posted
        ecking767
        • cadiman
          • Mar 2010
          • 397
          I do see a bit of a pattern on the pdp You may luck out. Again, Wizard is the expert here, The boards you need to be concerned with I think are along the bottom or top of the pdp. when you remove the back panel take a good picture. I have not looked at any panasonics yet to really be of any help here. good luck!
          Cadiman
          • PlainBill
            • Feb 2009
            • 7034
            I did notice a number of Panasonic troubleshooting manuals on Scribd. On their site search for 'Panasonic Plasma'.
            PlainBill
            • kevinallein
              • Dec 2010
              • 32
              Hi, did this ever get resolved ? I have here 3 x TH-42PV70P with similar colored vertical lines funny enough only in the middle half of the picture, so vertically the first and last quarter of the screen is perfect. I have swapped C boards and D boards between two of those units to see if the bad lines move with the boards, but that did not seem to be the case.
              I would be grateful for any hints, even if the answer is, that the Panels are dead. I was thinking of building a cable between one of the 4 x 68 pin HD connectors of the C boards and the Panel, so that I could e.g. connect the working first 64 columns to one of the failing segements to verify, that it is indeed the panel.
              Is this available professionally ? 68 pins with 0.5 mm pitch do seem like a challenge. Does anyone see a problem with trying that because of the extra cable in the path ?
              • ecking767
                • Oct 2009
                • 492
                Originally posted by kevinallein
                Hi, did this ever get resolved ? ?
                WOW !!! Blowing off the dust on the post. Time have when by so fast.
                I made a promise to myself to start fixing plasma TV.I have been working on LCD monitors and LCD TV. I'm currently working on a Panasonic TH-42PX60U with same problem.
                https://www.badcaps.net/forum/showthread.php?t=12572
                I still have the TH-42PX77U and I will start back troubleshooting it very soon.
                I will update this post as soon as I repair it or conclude other wise
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                  Having said that I come to the gist of my post on the forum as the title suggests.
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • lupinIII
                  Vertical Lines Panasonic Plasma Th-37PX80
                  by lupinIII
                  Hello everyone, I've been browsing this forum but I didn't find similar vertical lines like this on Panasonic Plasmas
                  So they are not all over the screen but there's lines on both halves of the screen. The lines are also present with no signal, at least some of them but I can't distinguish all of them with no input. With no input the vertical lines on the right side are definitely more visible.
                  It started with one line half a year ago, then two and has been increasing the number of lines.
                  Where or what could be the problem? What steps should I take?...
                  01-12-2020, 08:20 PM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
