TCL 65" U65E5800FS - Black shading after startup
 Re: TCL 65" U65E5800FS - Black shading after startup
 don't think theres a simple fix, going to need to pull the back cover off if you want to troubleshoot it, take some good clear straight on pictures of each board and one of the whole back, as to see how everything is connected, use the go advanced button to upload. It is kind of strange how it moves around, seems like a backlight issue, wonder if it's to do with the connections of the strips or such. They can start getting intermittent and act up, ever see one of those youtube videos where they whack the tv with a bat and it works? NEVER do that by the way, you can tap here and there but don't whack.Last edited by nomoresonys; 11-20-2022, 04:26 AM.Comment
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by estabilitoHi, I've just repaired acer nitro an515-55 with specs:
 i7-10750h, rtx2060.
 Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
 After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
 i've tried different bios, different vbios and same behaviour - clean windows install too.
 Do you have any idea?08-13-2025, 02:52 PM
			Hi everyone.
 Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
 Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
 Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
			Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
			by EthanMaiDELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
 ST-3L0GZB3
 needs cleaning.
 Please help me clean up the slow startup dump if you have time. Thank you....-
- Loading...
